munners
I have recently started to have a problem with my Leon 1.6 SX.
Every morning it won't start. The engine turnes over, it fires, but doesn't catch, so I have to try again and again and again until I eventually end up bumping it down the road. the battery seems healthy, as it continues to turn the engine over.
A couple of days ago, I thought I had found the knack, as when I had the accelerator pedal pushed all the way to the floor, it would start. Unfortunately, this morning that did not work, and I had to bump it again.
Once the car has started, it's fine all day. I have checked and cleaned the spark plugs, but this has not made any difference.
As far as I am aware, there have only been two things that have changed since this started playing up.
1. I put premium unleaded in it instead of the normal unleaded (and I haven't had to fill up again since).
2. The temperature has dropped below 0 degrees.
Any advice would be appreciated.
