Hi,
I have a 57 plate Leon MK2 and recently noticed whilst being seated in the car the window seals (running along the base of the window) all have moss / algae on them. Running my nail over it removes the moss but is this a normal thing? If so what do people usually clean it off with? I have had the notorious wet windows problem, is it related?
Furthermore, with regards to the wet windows issue, is it just a case of turning up to a SEAT dealership saying that you have the wet windows issue, and possibly stating the reference number which I believe is floating around on these forums, and then they will fix it under warranty? I have a horrible feeling that I will turn up and they will simply not believe that I have the fault.
Will be most grateful for any help,
Regards,
Regards,
