Mot failure cupra r emissions
teeth2k
908
sussex
My cupra r has failed on emissions
Fast idle speed
Engine speed = 5.14% fail-0.30
Lambda = 0.85 fail 0.97 min 1.03max
Second fast idle speed
Co level =2.93% fail-0.30
Lambda = 0.91 fail 0.97 min 1.03 max
Natural idle test fail
Co level = 2.93% fail 0.50
Any solutions on on what I can do?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
confirm with vcds what your cars b1s1 lambda says... on engine, block 031 it should show its actual lambda as it "thinks" its controlling to...
if there's an exhaust leak where additional air can be sucked in it can influence the tailpipe mot probe, however its reporting yours is rich not lean...
any present faultcodes?
water temp ok?
egt probe ok? fill over fuel if its faulty and thinks its hot
Dec 5, 2012
806
Harlow
That could cause the emissions to be high. The car will dump more fuel in to get the car up to temperature. Change the stat and temperature sensor
teeth2k
908
sussex
That's kind of when I was thinking, the mot station is less than 5 mins away from me and the car defo wasn't up to temperature,
Would CCDs pick up a lambda fault?
teeth2k
908
sussex
just ran vcds and it came back with this
1 Fault Found:
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
Readiness: 0000 0000
Dec 5, 2012
806
Harlow
EGT temp sensor. goes onto the turbo. that could cause overfuelling if it was faulty. when the egt sensor senses the turbo and manni are at a certain temperature the car will dump more fuel in to cool things down.
teeth2k
908
sussex
Cheers brad
I was reading this late last night and got me thinking, before the mot I changed the dipstick plastic holder and I had to unplug the egt sensor to get to it and guess what? I forgot to plug it back in :whistle:
Time for the re test me thinks
