mot failure
delboy21
74
Car failed its mot today on emissions
Fast Idle Test
CO=0.57 Fail
HC=00017 Pass
Lambda=0.99Pass
Second Fast Idle Test
CO=2.16 Fail
HC=00028 Pass
Lambda=0.94fail
Normal Idle Test
CO=0.50
its either my cat or my lambda sensers. Can anyone tell from these readings which it could be? As lambda sensors aint cheap and a new cat for my car is uber expensive.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
If it is the cat could be a good excuse to get a new sports cat:)
Not sure what it could be though, mine had its MOT 2weeks ago and passed on everything! Well chuffed as ive come from owning 3 fiats (fix it again Tony's) and they cost me an arm and a leg to keep on the road, good bless Spanish/German build quailty:)
delboy21
74
any techies know just by looking at the readings,must be someone in the trade that can tell
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
It's not the lambda probes... they wouldn't be working right (which they are)
Do you have a cat? that's what I'd replace
pick up a 2nd hand one for not too much
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it's likely.... however - how well serviced is it? check the air filter, plugs etc - when were they last replaced?
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
have this fault code and failed mot same as you looks like we have to change cat then
