kazzz25 Active Member Jul 17, 2025 58 2 Jan 2, 2026 #1 Hi, I seen that you use the reverse light switch to fill the gearbox oil. My question is can you syphon and refill using this pipe? Thanks
James_R 🏴🇩🇪🇪🇸 Staff member Moderator Apr 22, 2008 6,515 1,033 39 Manchester Jan 2, 2026 #2 You won't be able to push a pipe all the way to the bottom of the gearbox through that hole, so you can only use it for filling.
