My cupra isnt boosting
Nov 2, 2004
9,335
South Wales
I think MAF first, low g/s even if in limp mode is really low.
Have you tried clearing the codes and disconnectin the maf for a run to see if it runs a bit better?
djscorch
Innovate, don't imitate
Jun 30, 2006
398
Manchester
I can clear the codes for you tomorrow if you want mate.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
In your haste to fix your car your not listening to everyone Danny. Unplugging your MAF does not always tell you if it is knackered. Start here and get a genuine bosch one. Lambda could be a problem but changing all these things will cost you the best part of £300 and some of them may be totally good parts and changing them could mess it up more. N75 dont tend to fail and people only usually change thm to gain performance. One of those faults could be the secondary air injection system aswell but ignore for the moment as most of those faults can be caused by one part failing. Only get genuine parts for the things people have mentioned and not from ebay because they may not cure your problems.
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
i am listening mate...Otherwise i wouldnt of asked for help..
ive found a website called vagparts and they have mafs on there for 100quid bosch ones..
But i cant find the code on there to match my engine type AYP or the part number i got from the search..
the link to the page with the mafs on it...its in the vw mk4 golf bit under engine then there they are...
https://sslrelay.com/s74326199.onea...nid=15475711f27ede6/shopdata/index.shopscript
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Well erm this was weird..
Had a little trip round to adams tonight to clear all the fault codes...On the way there the car was the same no boost at all...
He then cleared all my faults/codes correctly via vagcom then i left soon as i started the car the gas pedal was really light..So then set off then heard the induction kit and dv so i was shocked..
I then turned out of his street and i had boost in every gear till 4.5krpm then goes straight in to limp mode..
So i turned it off then i had boost again till 4.5krpm so i have boost till i get that rpm range...
Never did this before ...
So gonna drive it abit then do another log/scan and see what comes up...
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
here are the main ones i do.
003 + 020 air flow + timming
115 + 031
118 + 032
you may want to do 14 as well to check the duty.
djscorch
Jun 30, 2006
398
Manchester
Quick scan today - this is the only fault coming back...
Overboost?
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
1 Fault Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Readiness: 0000 1001
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
You havent played about with your actuator have you?
If it turns out that its the N75 i have a std one here you can have for a couple of beer tokens.
