No worries, hope it stays sorted for you. :)
Do a ECU reset and a TBA while you have use of vag-com.
As there was abit of speculation about the MAF it might be worth logging that to make sure its not on its way out aswell.
If you done the bypass right then it should be ok,
But for a check, have a look at the N112 which has the vac lines connected to it to see if the third port on it is blanked off.
I dont the bypass on rogers' car and he had some problems and it was down to the 3rd port being open.
Do you mean the port circled in red - would a bit of hosing with a screw in the end do the job?
Nah the port i'm talking about in the pic above is where the two vac lines go to the N112.
Whats fault codes are you gettin when it goes into limp mode?
And come on, help us help you, we've only seen 2 logs in this 7 page thread and theyre next to useless as you only go to 4k.
He's getting...
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
I'm gonna tidy up the bypass for him and double check the port you mentioned. Other than that I think it's time for some more logs.
Nice one mate...
Code:
Group A:	'115					Group B:	'118
	RPM	Load	Absolute Pres.	Absolute Pres.			RPM	Temperature	Load	Absolute Pres.
TIME						TIME
STAMP	 /min	%	 mbar	 mbar		STAMP	 /min	°C	%	 mbar
0.35	2200	27.8	950	1020		0.01	2200	15	0	1020
1.15	2200	30.8	950	990		0.75	2200	15	0	990
1.95	2200	45.9	950	1010		1.55	2200	15	0	990
2.86	2200	28.6	950	990		2.46	2200	15	0	1010
3.66	2240	53.4	950	1010		3.26	2240	15	0	980
4.46	2280	46.6	950	1040		4.06	2240	16	0	1040
5.26	2280	43.6	950	1030		4.86	2280	15	0	1030
6.06	2320	42.1	950	1020		5.66	2280	15	0	1020
6.86	2320	42.1	950	1010		6.46	2320	15	0	1020
7.66	2320	48.1	950	1020		7.26	2320	15	0	1010
8.46	2360	52.6	950	1050		8.06	2360	16	0	1030
9.26	2400	51.9	950	1050		8.86	2400	16	0	1050
10.04	2440	82.7	1320	1070		9.66	2400	16	0	1050
10.84	2560	127.1	1460	1620		10.44	2480	17	6.7	1310
11.64	2680	129.3	1460	2170		11.24	2640	18	1.2	1920
12.46	2760	54.9	1000	1250		12.04	2720	18	1.2	1900
13.26	2840	82	1000	1360		12.84	2800	15	1.2	1190
14.16	2880	69.9	980	1390		13.66	2840	17	1.2	1470
15.05	2960	73.7	990	1370		14.65	2920	17	1.2	1360
15.85	3040	76.7	1000	1420		15.45	3000	18	1.2	1390
16.65	3080	73.7	990	1420		16.27	3040	18	1.2	1430
17.45	3120	73.7	980	1430		17.05	3080	18	1.2	1430
18.25	3200	72.2	970	1440		17.85	3160	18	1.2	1430
19.05	3240	66.9	950	1410		18.65	3200	18	1.2	1440
19.85	3280	63.9	950	1310		19.45	3240	18	0	1340
20.76	3320	63.9	950	1310		20.25	3280	18	0	1300
21.66	3320	63.2	950	1300		21.24	3320	18	0	1300
22.54	3360	60.9	950	1290		22.15	3360	19	0	1300
23.35	3400	60.2	950	1270		22.95	3400	19	0	1280
24.15	3440	59.4	950	1270		23.75	3400	19	0	1270
25.05	3440	57.9	950	1250		24.65	3440	19	0	1260
25.96	3480	58.6	950	1260		25.45	3440	20	0	1250
26.77	3480	57.9	950	1260		26.36	3480	20	0	1260
27.75	3520	68.4	950	1240		27.26	3520	20	0	1260
28.55	3560	71.4	950	1420		28.15	3560	21	0	1370
29.35	3640	65.4	950	1390		28.95	3600	21	0	1410
30.15	3640	54.9	950	1290		29.75	3640	21	0	1340
31.05	3640	48.9	950	1200		30.65	3640	21	0	1220
31.85	3680	42.9	950	1120		31.45	3640	21	0	1150
32.65	3680	42.9	950	1110		32.25	3680	20	0	1110
33.45	3720	85	950	1640		33.05	3680	21	0	1210
34.25	3760	60.2	950	1380		33.85	3720	21	0	1470
35.05	3760	33.8	950	1130		34.65	3760	21	0	1270
35.85	3720	26.3	950	1040		35.45	3720	21	0	1070
36.65	3680	18	950	1010		36.25	3720	20	0	1030
37.54	3640	20.3	950	990		37.14	3640	20	0	1000
38.46	3600	36.1	950	1060		37.94	3640	20	0	980
39.34	3560	7.5	950	1010		38.86	3560	20	0	1040
40.14	3480	9	950	990		39.74	3520	20	0	1000
40.95	3400	9	950	990		40.55	3440	20	0	990
41.83	3320	9	950	990		41.43	3360	20	0	990
42.63	3240	20.3	950	970		42.23	3280	20	0	990
43.55	3360	138.3	1490	1660		43.03	3280	21	23.1	1000
44.34	3480	127.8	1470	2260		43.94	3400	24	1.2	2200
45.14	3520	59.4	970	1260		44.74	3520	22	1.2	1620
45.94	3560	76.7	950	1450		45.54	3560	21	0	1320
46.74	3600	69.9	950	1450		46.34	3600	21	0	1470
47.54	3640	69.2	950	1430		47.14	3640	22	0	1440
48.34	3680	68.4	950	1430		47.94	3680	23	0	1430
49.16	3720	69.2	950	1440		48.74	3720	23	0	1440
50.04	3760	66.2	950	1440		49.64	3760	23	0	1450
50.95	3800	66.9	950	1430		50.44	3800	24	0	1430
51.85	3840	65.4	950	1430		51.37	3800	24	0	1430
52.84	3880	75.2	1010	1530		52.34	3840	24	1.2	1480
53.75	3920	72.9	1000	1520		53.24	3880	24	1.2	1530
54.53	3960	72.9	1000	1520		54.13	3920	24	1.2	1520
55.33	4000	71.4	990	1520		54.93	3960	25	1.2	1520
56.13	4040	71.4	980	1520		55.73	4000	26	1.2	1520
56.93	4040	71.4	980	1530		56.53	4040	26	1.2	1530
57.73	4080	71.4	970	1540		57.33	4080	26	1.2	1530
58.53	4120	69.2	950	1540		58.13	4120	27	1.2	1550
59.33	4160	69.9	950	1530		58.93	4120	27	0	1530
60.13	4200	70.7	960	1540		59.73	4160	27	1.2	1530
60.93	4200	69.9	950	1540		60.53	4200	27	0	1550
61.84	4240	69.9	950	1550		61.33	4240	28	0	1540
62.64	4280	69.9	950	1560		62.24	4280	28	0	1550
63.44	4280	69.9	950	1560		63.04	4280	29	0	1560
64.24	4320	69.9	950	1560		63.84	4320	29	0	1550
65.05	4320	69.9	950	1560		64.64	4320	29	0	1560
65.84	4360	69.9	950	1570		65.44	4360	30	0	1560
66.64	4400	68.4	950	1570		66.24	4360	30	0	1560
67.44	4400	67.7	950	1540		67.05	4400	30	0	1550
68.34	4400	67.7	950	1540		67.83	4400	30	0	1540
69.14	4440	68.4	950	1550		68.74	4440	30	0	1550
69.94	4440	68.4	950	1550		69.54	4440	31	0	1550
70.74	4480	67.7	950	1560		70.34	4440	31	0	1550
71.63	4480	67.7	950	1550		71.23	4480	32	0	1550
72.44	4520	63.2	950	1510		72.03	4520	32	0	1550
73.23	4520	63.9	950	1480		72.83	4520	32	0	1480
74.03	4480	49.6	950	1280		73.63	4520	32	0	1430
74.93	4480	29.3	960	1090		74.53	4480	31	0	1230
75.83	4400	16.5	950	1060		75.33	4440	30	0	1080
76.63	4320	7.5	950	1010		76.23	4360	29	0	1030
77.43	4200	9	950	1000		77.03	4280	29	0	1000
78.32	4120	9	950	1000		77.92	4160	29	0	1000
isnt 118 log to see ive got a boost leak?How can u read it?
This is the error code im gettin
http://wiki.ross-tech.com/index.php/17963/P1555/005461
What charge control unit and variable nozzles?Im gonna do a prober log 2morro
Logs need to be done flat out from around 2k-redline in 3rd or 4th gear if possible. Did you change you MAF? You really need to clear all fault codes and do a throttle body alignment before any more logs.
I cant see it being a boost leak. You say the cars standard? your seeing major over boost there at 18psi which are quite aggressive boost levels for a mapped car. I would say either a jammed wastegate or faulty N75 valve or something is plumbed in wrong. Have you got a boost gauge? If so whats it reading? Similar readings to vag-com? If not could be your MAP sensor playing up.
Block 118 shows your 'actual' boost and wastegate duty, basically how hard your turbo is working to achieve the requested boost. Your logs show abnormal wastegate duty readings which usually point at a faulty N75 valve or faulty wastegate or actuator.
The Items ive changed so far are Cts,N75 and ive returned the n249 back to standard tonight aswell
Ive also cleard the codes and the same code keeps coming back...Before disconnecting my boost gauge it was hitting 1 bar on my gauge then goin in to limp mode...
Done some logs 2night and adam will post them up and explain what has happened..
Code:
Friday	21	December	2007	18:37:29
6K0 906 032 AA 		1.8L 20VT EU3       0002
	Group A:	'002				Group B:	'020				Group C:	'114
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		Load	Load	Load	Load
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP	%	%	%	%
2	98.86	3880	66.2	8.61	45.92	99.28	0	0	0	0	98.46	117.3	74.6	82	0
	100.16	3920	69.9	8.61	51.39	100.55	0	0	0	0	99.76	117.3	74.6	69.9	0
	101.37	3960	69.9	9.02	53.58	101.75	0	0	0	0	100.95	117.3	74.6	70.7	0
	102.65	4000	69.9	9.02	52.58	103.05	0	0	0	0	102.25	117.3	74.6	69.9	0
	103.85	4000	69.9	8.61	54.25	104.25	0	0	0	0	103.45	117.3	74.6	69.9	0
	105.05	4040	69.9	8.61	54.17	105.45	0	0	0	0	104.65	117.3	74.6	69.9	0
	106.25	4040	69.9	9.02	53.64	106.65	0	0	0	0	105.85	117.3	74.6	69.9	0
	107.45	4080	69.9	8.61	54.83	107.85	0	0	0	0	107.05	117.3	74.6	69.9	0
	108.75	4120	69.9	8.61	54.78	109.14	0	0	0	0	108.34	117.3	73.1	69.9	0
	109.95	4160	69.9	8.61	55.22	110.34	0	0	0	0	109.55	117.3	73.1	69.9	0
	111.15	4200	69.2	8.61	56.67	111.64	0	0	0	0	110.75	117.3	73.1	69.9	0
	112.44	4240	71.4	8.61	57.83	112.95	0	0	0	0	112.04	117.3	73.1	69.2	0
	113.74	4280	71.4	9.43	59.03	114.14	0	0	0	0	113.34	117.3	71.6	71.4	0
	114.94	4320	71.4	8.61	58.89	115.34	0	0	0	0	114.54	117.3	71.6	71.4	0
	116.14	4360	72.2	9.02	60.81	116.54	0	0	0	0	115.75	117.3	71.6	71.4	0
	117.34	4400	72.2	9.02	61.22	117.74	0	0	0	0	116.94	117.3	71.6	72.2	0
	118.54	4440	71.4	8.61	60.72	119.05	0	0	0	0	118.14	117.3	71.6	71.4	0
	119.85	4520	70.7	9.02	60.94	120.25	0	0	0	0	119.45	117.3	70.1	70.7	0
	121.05	4560	69.9	9.02	61.06	121.45	0	0	0	0	120.65	117.3	70.1	70.7	0
	122.25	4560	69.9	9.02	62.11	122.65	0	0	0	0	121.85	118	70.1	69.9	0
	123.45	4600	69.2	8.61	59.97	123.85	0	0	0	0	123.05	118	70.1	69.2	0
	124.65	4640	68.4	8.61	61.22	125.05	0	0	0	0	124.25	118	68.7	69.2	0
	125.83	4680	67.7	9.02	61.42	126.23	0	0	0	0	125.45	118	68.7	68.4	0
	127.03	4720	68.4	8.61	62	127.43	0	0	0	0	126.63	118.8	68.7	67.7	0
	128.23	4720	62.4	8.2	57.5	128.63	0	0	0	0	127.83	118.8	68.7	57.9	0
	129.43	4720	63.2	7.79	56.06	129.83	0	0	0	0	129.03	118.8	68.7	63.2	0
	130.63	4720	56.4	7.38	49.97	131.03	0	0	0	0	130.23	118.8	68.7	59.4	0
	132.04	4720	67.7	8.61	61.39	132.44	0	0	0	0	131.54	118.8	68.7	66.9	0
	133.24	4720	65.4	8.2	58.33	133.74	0	0	0	0	132.84	118.8	68.7	66.2	0
	134.53	4760	64.7	8.2	59.53	134.93	0	0	0	0	134.13	118.8	68.7	64.7	0
	135.73	4760	64.7	8.2	58.06	136.23	0	0	0	0	135.33	118.8	68.7	64.7	0
	137.14	4800	63.9	8.2	58.06	137.54	0	0	0	0	136.74	119.5	68.7	63.9	0
	138.34	4800	57.1	7.38	51.78	138.72	0	0	0	0	137.94	119.5	68.7	57.9	0
	139.52	4800	60.9	7.79	56.75	139.92	0	0	0	0	139.12	119.5	68.7	48.1	0
	140.72	4800	53.4	6.56	48.25	141.13	0	0	0	0	140.34	119.5	68.7	54.1	0
	141.92	4800	65.4	8.61	61.97	142.32	0	0	0	0	141.52	119.5	68.7	58.6	0
	143.12	4840	63.9	8.2	58.69	143.52	0	0	0	0	142.72	119.5	67.2	64.7	0
	144.44	4720	8.3	0	7.42	144.84	0	0	0	0	143.92	118.8	68.7	10.5	0
	145.64	4400	9.8	0	9.08	146.11	0	0	0	0	145.23	117.3	70.1	9.8	0
	147.01	4240	9.8	0	8	147.41	0	0	0	0	146.61	117.3	71.6	9.8	0
	148.21	4120	9	1.23	7.06	148.63	0	0	0	0	147.81	117.3	73.1	9.8	0
	149.52	4040	18	2.46	14.14	150.02	0	0	0	0	149.12	117.3	74.6	18.8	0
	150.83	3960	13.5	1.64	11.47	151.23	0	0	0	0	150.43	117.3	74.6	10.5	0
	152.02	3920	38.3	5.33	31.5	152.42	0	0	0	0	151.63	117.3	74.6	32.3	0
	153.22	3920	39.1	4.92	29.08	153.62	0	0	0	0	152.82	117.3	74.6	39.8	0
	154.42	3920	39.1	4.92	29.06	154.82	0	0	0	0	154.02	117.3	74.6	38.3	0
	155.81	3920	36.8	4.92	27.33	156.23	0	0	0	0	155.33	117.3	74.6	37.6	0
	157.12	3920	36.8	4.92	27.03	157.52	0	0	0	0	156.72	117.3	74.6	37.6	0
Code:
Friday	21	December	2007	18:33:01
	Group A:	'118				Group B:	'001				Group C:	 Not Running
		RPM	Temperature	Load	Absolute Pres.		RPM	Temperature	Lambda	Bin. Bits
	TIME					TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP	 /min	°C	%		STAMP
	0.55	2400	21	0	1030	0.95	2360	81	6.3	1100001
	1.35	2360	20	0	1040	1.75	2360	81	8.6	1101001
	2.15	2360	21	0	1020	2.55	2400	81	7	1100001
	2.95	2400	21	25.1	1220	3.35	2480	81	0	1100001
	3.84	2560	21	1.2	1950	4.24	2640	80	0	1100001
	4.66	2640	21	0	1940	5.15	2720	81	7.8	1100001
	5.63	2720	19	1.2	1250	6.05	2760	80	8.6	1100001
	6.43	2800	20	0	1410	6.83	2840	80	12.5	1100001
	7.25	2880	21	0	1400	7.63	2880	80	14.1	1101001
	8.05	2920	21	0	1390	8.55	2960	80	13.3	1101001
	8.95	3000	21	0	1370	9.35	3000	80	14.8	1101001
	9.75	3040	21	0	1380	10.15	3080	80	11.7	1101001
	10.55	3080	21	1.2	1380	10.95	3120	80	13.3	1101001
	11.35	3160	21	0	1430	11.75	3160	80	12.5	1101001
	12.15	3200	21	0	1420	12.55	3240	80	12.5	1101001
	12.95	3240	21	0	1400	13.35	3280	80	15.6	1101000
	13.75	3280	21	0	1310	14.15	3320	79	12.5	1101000
	14.55	3320	21	0	1320	15.04	3360	79	14.1	1101000
	15.44	3360	21	0	1310	15.95	3400	79	9.4	1101000
	16.35	3400	21	0	1240	16.75	3400	79	8.6	1101000
	17.15	3400	21	0	1240	17.55	3440	79	12.5	1101000
	18.05	3440	21	0	1240	18.45	3440	79	7.8	1101000
	18.94	3480	21	0	1240	19.34	3480	79	12.5	1101000
	19.74	3480	21	0	1230	20.14	3520	79	10.9	1101000
	20.53	3520	21	0	1200	21.04	3520	79	10.2	1101000
	21.44	3520	21	0	1160	21.84	3520	79	10.2	1101000
	22.24	3560	21	0	1180	22.64	3560	79	7.8	1101000
	23.04	3600	23	0	1370	23.44	3600	79	7.8	1101000
	23.84	3640	23	0	1570	24.24	3680	79	6.3	1101000
	24.64	3720	23	1.2	1510	25.04	3720	79	7	1101000
	25.44	3760	23	0	1520	25.84	3800	78	6.3	1101000
	26.22	3800	24	0	1520	26.64	3840	79	7	1101000
	27.04	3840	24	0	1520	27.54	3880	78	6.3	1101000
	28.05	3920	24	0	1530	28.45	3920	78	9.4	1101000
	28.85	3960	24	0	1480	29.25	3960	79	2.3	1101000
	29.65	4000	24	0	1480	30.05	4000	79	0.8	1101000
	30.45	4000	24	0	1310	30.85	4040	79	3.1	1100000
	31.25	4040	24	0	1350	31.65	4080	79	3.1	1100000
	32.05	4080	24	0	1400	32.43	4080	78	2.3	1100000
	32.85	4080	24	0	1410	33.23	4120	78	0.8	1100000
	33.63	4120	24	0	1380	34.03	4120	78	4.7	1101000
	34.45	4120	24	0	1320	34.83	4160	79	0.8	1101000
	35.23	4160	25	0	1370	35.63	4160	78	3.9	1100000
	36.03	4160	25	0	1410	36.43	4200	78	0	1100000
	36.83	4200	25	0	1400	37.23	4200	78	0	1100000
	37.63	4240	26	0	1420	38.03	4240	78	0.8	1100000
	38.43	4240	26	0	1430	38.83	4280	78	0.8	1100000
	39.23	4280	26	0	1430	39.63	4280	78	3.9	1100000
	40.03	4280	26	0	1430	40.43	4320	78	0	1100000
	40.83	4320	27	0	1440	41.23	4320	78	0	1100000
	41.63	4320	27	0	1440	42.03	4360	78	2.3	1100000
	42.43	4360	27	0	1440	42.94	4360	78	3.1	1100000
	43.34	4360	27	0	1450	43.74	4400	78	1.6	1100000
	44.14	4400	27	0	1440	44.54	4400	78	0	1100000
	44.94	4400	27	0	1450	45.34	4440	78	0.8	1100000
	45.74	4440	27	0	1450	46.12	4440	78	-0.8	1100000
	46.53	4440	28	0	1450	46.92	4440	78	0.8	1100000
	47.34	4480	28	0	1450	47.72	4480	78	2.3	1100000
	48.12	4480	28	0	1450	48.53	4480	78	3.1	1100000
	48.92	4480	28	0	1440	49.32	4480	78	4.7	1100000
	49.72	4480	29	0	1540	50.12	4520	78	3.9	1100000
	50.53	4520	29	0	1520	50.92	4520	78	2.3	1100000
	51.44	4520	29	0	1480	51.93	4560	78	3.1	1100000
	52.33	4560	29	0	1470	52.73	4560	78	0	1100000
	53.13	4560	30	0	1480	53.53	4560	78	0.8	1100000
	53.93	4600	30	0	1490	54.33	4600	78	0	1100000
	54.73	4600	30	0	1490	55.23	4600	78	2.3	1100000
	55.63	4600	30	0	1490	56.03	4600	78	0	1100000
	56.52	4600	30	0	1490	56.92	4640	78	0.8	1100000
	57.43	4640	30	0	1480	57.83	4640	78	0	1100000
	58.23	4640	30	0	1490	58.62	4640	78	2.3	1100000
	59.02	4640	30	0	1500	59.42	4640	78	1.6	1100000
	59.82	4640	30	0	1490	60.22	4680	78	0	1100000
	60.63	4680	31	0	1500	61.02	4680	78	0	1100000
	61.42	4680	31	0	1500	61.82	4680	78	0	1100000
	62.22	4680	31	0	1500	62.62	4680	78	0	1100000
	63.02	4680	32	0	1500	63.42	4680	78	0	1100000
	63.82	4720	32	0	1500	64.22	4680	78	0	1100000
	64.62	4720	32	0	1510	65.02	4720	78	0	1100000
	65.42	4720	32	0	1530	65.82	4720	78	0	1100000
	66.22	4720	32	0	1530	66.62	4720	78	0	1100000
	67.02	4720	33	0	1530	67.42	4760	78	0	1100000
	67.93	4760	33	0	1520	68.33	4760	78	0	1100000
	68.73	4760	33	0	1520	69.13	4760	78	0	1100000
	69.53	4760	33	0	1520	69.93	4760	78	0	1100000
	70.33	4760	33	0	1520	70.73	4800	78	0	1100000
	71.13	4800	33	0	1520	71.51	4800	78	0	1100000
	71.93	4800	33	0	1440	72.31	4800	78	0	1100000
	72.71	4800	33	0	1430	73.11	4800	78	0	1100000
	73.51	4800	33	0	1440	73.91	4800	79	0	1100000
	74.31	4800	33	0	1460	74.71	4800	78	0	1100000
	75.11	4840	33	0	1460	75.51	4840	78	0	1100000
	75.91	4840	34	0	1450	76.31	4840	78	0	1100000
	76.71	4840	34	0	1460	77.11	4840	79	0	1100000
	77.51	4880	34	0	1460	77.91	4880	78	0	1100000
	78.31	4880	34	0	1470	78.71	4880	78	0	1100000
	79.11	4880	34	0	1470	79.51	4920	78	0	1100000
	80.02	4920	34	0	1470	80.42	4920	78	0	1100000
	80.82	4920	34	0	1460	81.22	4920	78	0	1100000
	81.62	4920	35	0	1470	82.02	4960	78	0	1100000
	82.42	4960	35	0	1470	82.82	4960	79	0	1100000
	83.22	4960	35	0	1470	83.62	4960	78	0	1100000
	84.02	4960	34	0	1400	84.41	5000	78	0	1100000
	84.82	5000	35	0	1440	85.22	5000	79	0	1100000
	85.61	5000	35	0	1440	86.02	5040	79	0	1100000
	86.41	5040	35	0	1440	86.81	5040	78	0	1100000
	87.21	5040	35	0	1440	87.61	5040	78	0	1100000
	88.01	5080	36	0	1510	88.4	5080	78	0	1100000
	88.81	5080	36	0	1490	89.2	5080	78	0	1100000
	89.6	5080	36	0	1460	90	5120	79	0	1100000
	90.4	5120	36	0	1440	90.81	5120	78	0	1100000
	91.2	5120	36	0	1410	91.6	5120	78	0	1100000
	92	5120	36	0	1450	92.4	5080	78	0	1110000
	92.92	5080	34	0	1150	93.32	5120	78	0	1100000
	93.72	5040	35	0	1800	94.12	5040	78	0	1100000
	94.52	5040	35	0	1460	94.92	5040	79	0	1100000
	95.32	5040	34	0	1300	95.72	5000	78	0	1110000
	96.2	4880	33	0	1080	96.61	4800	78	0	1110000
	97.09	4680	33	0	1050	97.49	4600	78	0	1110000
	97.91	4480	33	0	1050	98.31	4440	78	0	1110000
	98.8	4400	32	0	1050	99.3	4360	78	0	1100000
	99.7	4320	32	0	1030	100.1	4280	78	4.7	1101000
	100.5	4280	32	0	1110	100.9	4280	78	6.3	1101000
	101.3	4280	31	0	1150	101.7	4240	78	-3.1	1111000
	102.19	4160	30	0	1060	102.61	4160	78	0	1100000
	103.11	4120	30	0	1030	103.51	4120	78	3.1	1101000
	103.92	4080	30	0	1040	104.31	4040	78	3.1	1101000
Some more logs there. It looks like half of them are missing but they are complete!
When Danny puts his foot on the accelerator the car gets upto about 4K and limp mode kicks in, from then on there is no power at all and it takes ages to get upto 5K - and thats as far as it will go.
Those maf readings look pretty suspect to me. Can you try Adams maf maybe just to eliminate it? Also the n75 duty looks all over the shop, you should be seeing consistent readings there ranging anywhere up from 50% i would have thought.
I still think it looks wastegate/actuator related.
