Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
I'd go with a 18g,depends whether jabba can/will map it for you.Other option is owens ihi/gt30 hybrid.Is it under warranty?do you have standard internal?what boost were you running?
was fitted by jabba 2000 mile ago befor i got the car was told warranty is with the person that payed the bill
You can get a small td06 compressor housing,the 8cm is the exhaust housing and it will bolt up directly to the standard manifold,the only issue is that it might just foul as we have seen with dan-ish proper td06.Personally i think the vf34 is a small turbo capable of 340bhp maximum.A proper 18g will do 380bhp no problem.
Mine might have expired after 2000 miles too but this looks like a valve will have caused the damage (if there is damage yet to check). I however was running 1.5 bar but it was no where near as hard mapping as the likes of Jools (custardcupra) as his with the P20 still spooled well mine always felt laggy.
As soon as I've stripped mine down there will be a 'looks whats failed' thread to warn people, and I really wished I'd seen Bill's thread regarding fitting a £375.00 set of one piece valves before going IHI. When I spoke to Jabba regarding internals I was told not to worry or waste my money, and there would be no problems on the standard valves... oops.
If my VF34 P20 is dead I'll be looking into the likes of the above mentioned, but untill I actually know whats wrong I can't comment too much. Need to find out what is wrong before throwing away £££.
I'm undecided on mapping, if Mike will map another turbo fair play, if not I'll need to find somewhere willing to do it.
