good results there then shows can pull some good power with revo stage 2 on.
hope i cna get mine all up and running to a simular power.
It does show that there is power to be had, but its a shame you have to pretty much set it up yourself unlike 'custom' maps. Although its quite fun in doing it yourself and satisfiying when it pulls figures like these.
yea i know its abit of a pain but give you abit more control over your setup i suppose in a way.
would still like to turn the boost up abit more though think that can go higher.
I`ve added around 5.75 deg with lemmiwinks,but that was with a fair bit of logging and letting it adapt after each adjustment. But as phil says water/meth is next on the list and then should be able to add quite abit more.
I think you could proberly get abit more if you wanted jay, Crank the WG abit to bring the duty down and maybe add some timing via lemmiwinks if its possible with your map. Might be worth a PM to will to see if it is possible although from logs ive seen from p torque maps timing pull is already quite high.
That was a good blast down that bypass Dan, i though you were just saving on petrol. My mate with the C2 couldnt belive how quick i passed you lot. :whistle:
Think i'll ask see what can/could be done to the map.
You never know
Jay, If it is possible, im fairly sure it can as ive read somwhere that jabba have used lemmiwinks to adjust timingon there maps. Ill meet up with you and we can get some logs done to see what kind of timing pull you have and adjust to suite.
Yes that wouldn't be a problem if you can let me know asap that you want to go and can get you and your mates name down of the list for the RR.
Sorry mate missed your post didnt think you replied so booked in today :( anyways im booked in on wednesday 6th of feb at 1.30 so if anyones about come over and say hi :)
