i have seen k03 cupra's run 220 ish hp so ko3s should get between 230 - 250 imo
Bergs k03s ran 234.5bhp with lots of torque so saying amds may be 10 bhp higher maybe right
But if you've got a print out for 250bhp then you've got bragging rights there on paper, that will shut most people up in the pub.
That's how I'd look at it :)
so you are only person with accurate rollers!! I don't understand how people were getting results within 5bhp of there known power, but mine is way out supposedly?
before you get all arsey :rolleyes: about your figure being doubted...... its well known and understood the phenomena of dyno lottery.
some dyno's read higher than realistic figures.. simple as.
250bhp from k03 :no: is unlikely on other dynos... but the lottery applies.
I am very happy how mine reads, and the power I measure equates to the level of arflow and tune I see (and do) - they have never, ever, made that level of power level.. and stock cars also make stock power here.. My dyno is not run in inertia mode, unlike some, which seem to read higher when spikey boost accelerates the rollers, as opposed fixed rpm/sec acceleration rates
a.n.other car at the same day you went to, was +20bhp on the dyno it was mapped on only a few days earlier.. Same car will be here this sunday, so we will see the lottery numbers compare.
dont get too hooked up on the numbers.. if its going well enjoy it..
it is'nt 250bhp however on rollers such as mine.... which I know to be accurate as far as I'm concerned.
enjoy
:thumbup:
Im pretty sure its a going FACT that a k03s cant realistically reach those sort of figures
As mentioned though dyno lottery applies, aslong as the car is well and does what its supposed to then it doesnt matter
It will look good on a pistonheads advert though as most "stage 1" cupras on there are claiming 250+bhp lol
Before my k03s I had mine RR'd at AMD it came out at 200bhp dead which also matched the logs me and a friend had done previously.
I recently had mine mapped at Jabba and it put out 241bhp and 300 ft/lbs.
I am totally aware of the dyno lottery and that mechanically speaking a k03s can't really achieve above 230 however it drives sooooo smoothly now and I am loving it!
As said the figures are there for pub talk and proof is on the paper when asked.
Big update just got back from Amd car made 764bhp and 876ft/lb
I'm pretty happy with the results. Not bad for a turbo the size of jammy dodger
I made 217bhp @ 0.8 bar on stage 1 map with ko3s on Dyno dynamic rollers @ monster motorsport.
so who are good dyno ppl in west midlands as i want to get my car RR
Made be it's reading from the fly wheel as I am running ko3s stage two revo uprated injectors pump and four bar pressure regulator and I am making 208 bang on at the wheels but when it was in psi they said just over 240 at the fly and if I want more it's time for a hybrid as the ko3s won't handle any more
