My leon cupra 305 whp ... 340 engine hp.. 50 kg*m
cupra-tfsi
31
Hi guys...
This my Cupra tfsi.. with:
1) Full Exhaust 76mm with 200 kat Milltek
2) apr carbonio intake + kn panel filter
3) ngk spark plugs IX iridium
4) S3 oem Intercooler
5) Forge remote divert valve
6) Bonalume Power pop off code: PS3
7) KMD fuel pump + cam follwer
8) ECU REMAP
9) eibach anti roll bar 26mm fw 23mm rear
10) eibach red spring
11) all powerflex support...
This is the dyno result... I appreciate all your comments........ h t t p : //img522.imageshack.us/img522/2176/25042009060800x600.jpg
I appreciate all your comments.... to improve the performance , to avoid breakage, alllll...
Now i think to order quaife and sachs performance clucth and toyo r888.
I hope with this items to improve the traction.. now is low.....:think::think:
Poverty
dyno dependant, but for your mods ideally it should be running around 360hp.
AMD Essex had a S3 in two or so days ago with similiar mods and made 375hp.
Blade
1,386
32
Hi guys...
8) ECU REMAP
What software are you running?
cupra-tfsi
31
looks a bit weird , most grphs show 200+ bhp over what it makes
dyno max power is 500 hp 4x4. i have custom ecu... initial i have install a map with max boost 2,05 bar.. and costant boost until 5500rpm of 1,60 bar and from 5600 rpm 1,4 bar until 6700rpm and then 1,25 until 7000rpm , unfortunately i don't have perform a dyno test because I was afraid that I would have broken all..... Now i have 340 hp + 50 kg*m because i have install a map with 1,75 max boost... and costant boost until 5500 rpm of 1,40 and after 1,3-1,2 bar until 7000 rpm.
Blade
1,386
32
So if your running 2.05bar - thats 29.73psi on a standard turbo - Wow, don,t think it will last long. I run max boost of 1.35bar to obtain my power output.
luke07cupra
Wind the boost up...
Apr 13, 2009
217
Leeds
What a safe maximum level of boost? Think mine peaks at 2520 millibar which is about 1.5bar right? - thats on Revo stage 1, going for stage 2+ shortly, not sure if thats ups the boost further...
Al
7,326
9
Whats your wheel horsepower figure mate?
cupra-tfsi
31
For this reason i have reduce the pick pressure a 1,75 for the standard k04 turbo and continuos boost of 1,4 bar until 55000 rpm and 1.3-1.2 bar until 7000 rpm , but i want to know if your pressure of 1,35 is costant until 7000 rpm or no...!?!?
