Had my leon cupra Tdi for just over a week, It was in need of some Tlc, so i have been V Busy ..
Thought i would treat it to new filters & oil Etc all round...
Came to remove the sump plug & all it did was turn, Only finger tight also & suffering with a slight oil weep !!!
Fcuk I thought ... managed after a short while to get it out, By using mole grips on the flats, Pulling a twisting ...
Somebody had stripped the threads on both the sump plug & in the sump, Wrapped lots of Ptfe around the plug & popped it back in finger tight...
Feckers...
So !? what to do now... ?? Went to my local motor factors & got a selection of sump plugs, Tried most & no joy .. Tried finding a taper seat self tapping bolt, !! May as well of been asking for Rocking Horse Sh!t !!!
From a rough measurement the Seat plug was approx 14mm, In my selection i had an approx 16mm Peugot sump plug, Just too big to fit, So armed with the peugot plug, went in search of a Tap & drill !! Borrowed one from a friends Hydraulic shop & then preceded to drill & tap out in situ.... Low & behold, It appears to have done the Job
Swarf i hear you say !!?? Well the required drill size was wound in virtually by hand .. & the peugot plug was quite short in length, So i did not need to go full depth as such.. Plus i washed the sump out again & again with old engine oil ...
Managed to get myself out of some one elses fcuk up there & a Mini Crisis there for me ...
Dean
Feckers...So !? what to do now... ?? Went to my local motor factors & got a selection of sump plugs, Tried most & no joy .. Tried finding a taper seat self tapping bolt, !! May as well of been asking for Rocking Horse Sh!t !!!
Dean
