Had a spare half hour today so thought I'd have a crack at my homemade cold side relocation kit (as seen on murdered LCR old readers ride)
I needed to change the throttle body to MAP pipe as this was the only pipe I didn't change when the FMIC went on.
Firstly I took the old pipe off and started to cut the two 90 63mm bends I ordered to make the same shape as the existing.
Then to fit in into the bay. I fitted it one piece at a time because it worked easier for me
Removed the dump valve pipe from the charge pipe then added the 90 barbed bend into the TIP
Blanked off the charge pipe
Then to cut a small length of pipe to come off the throttle body pipe for the new DV location
This bit you need to think about so it doesn't hit the bonnet
Then i Joined up the dv to TIP connection
Tighten up and refitted the engine cover
And that's it done!!!
Just need to get the polished forge charge pipe and have a go at the mani but I'm pleased with my dirty bay so far
