i have PHEVUnless you have a phev, just don't bother. It's not very useful, runs like you're on dial up broadband, and you won't miss it when your licence expires. I don't!
At least you can login. My app does nothingThe new My Cupra app seems absolutely woeful. Driving Data is unreadable, changing display units in burried under 'Account', and that's just about all I've tried to do. Can't get back into the old app either now, perhaps once you've used the new one, you can't login to the old app.
I’m also from the Netherlands, the app is not working at all.The new My Cupra app is working fine here in The Netherlands. Much faster than the old app. A downside is that there is no security on the app when you open it. Everyone can open it.
Driving data - utterly useless, doesn’t fit the screen - on iPhone SE or iPad, numbers wrap to line below, data and buttons are off the screen - can’t resize or scroll the screen.The new My Cupra app seems absolutely woeful. Driving Data is unreadable, changing display units in burried under 'Account', and that's just about all I've tried to do. Can't get back into the old app either now, perhaps once you've used the new one, you can't login to the old app.
Have worked out what the five year old failed to do - to take into account Dynamic Text Sizing on the iPhone, so if you make the text larger than default the Driving Data page can't handle the larger font size , lines fall off the screen and the chart fails to scale correctly.Driving data - utterly useless, doesn’t fit the screen - on iPhone SE or iPad, numbers wrap to line below, data and buttons are off the screen - can’t resize or scroll the screen.
Was this designed by a 5 year old?
You said Designed ??Driving data - utterly useless, doesn’t fit the screen - on iPhone SE or iPad, numbers wrap to line below, data and buttons are off the screen - can’t resize or scroll the screen.
Screen shotsHave worked out what the five year old failed to do - to take into account Dynamic Text Sizing on the iPhone, so if you make the text larger than default the Driving Data page can't handle the larger font size , lines fall off the screen and the chart fails to scale correctly.
I have had similar problems with the My Cupra app. Cupra Connect customer support sent me this info. It has worked for me ??
Spot on with this btwUnless you have a phev, just don't bother. It's not very useful, runs like you're on dial up broadband, and you won't miss it when your licence expires. I don't!
Exactly the page in the app that I never use ?Screen shots
As it is with text size increased, note the top row (distance and time) missing, data select button at bottom missing, graph scale wrong.
As it should be (with text size set to nominal). In addition: Where's the end time of the trip as per previous app? Why does it show 313.9 mpg when car and previous app always shows 300mpg for an EV only trip?
I don't think it does, no. Or at least I've not seen one, but my phones notification settings are a bit messed up.Hello to everyone. Does the new app inform you on when your Formentor is fully charged for the eHybrids? I found out that on the new app this notification is active only for the fully electric models. Is that correct?
Thanks for the reply. The previous App however used to notify when car was fully chargedI don't think it does, no. Or at least I've not seen one, but my phones notification settings are a bit messed up.
