can anyone confirm the size of the nipple under inlet manny to the left of the fpr one... larger than the frp nipple, im now going to run vac source direct to dv top, which iirc is 4mm then put the fpr vac source back where it was.
also can i get reducers for silicone hose? woul prefer not to tbh, ive seen robdon is using some sourt of connector on the top of his dv, id like to do the reduction there if possibl, so run 8mm or whatever size it is to the dv then reduce with a l shaped connector to the dv size... if that makes sense?
everytime.
