Yeah i did mine from the same thread. What i'm saying is the bottom pipe from the n 112- where does this go? we could actually do with a full guide or "schematic diagram" of the vac pipes. i've had an issue where my vac pipes were removed and now i'm confuddled as to where some of the pipes go. I've had a few "remove the sai" answers, but i'd rather just plumb things back in.
Which bottom pipe..??
There is 2 coming off the n112 one goes to the black and white check valve..
The other goes down under the charge pipe at the rear of the block...if your that unsure i will take a couple of pictures for you when i get in from work.
