N249 delete .. need some help
CPTHEBOY84
27
SCOTLAND
Im looking to do n249 and n75 delete . Anyone on here able to help me out , seen few posts with pics but cant really see the writing so finding it a bit hard to follow . 2003 cupra , turbo back stainless ,mapped ,induction kit . Having boost issues . I installed new n75 made no diff 8nstalled new recirculation valve still no difference . It does boost well sometimes other times its bad . Went through all hoses found 1 from n75 down to big metal pipe was slightly big for the n75 so slipped smaller hose over an clamped it down worked for a bit but back to intermittent boost issue . Just want shot of the 249 and 75 altogether . Anyone that could help me through it it would be appreciated
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,133
677
Leeds
Basicly for the n249 delete you remove everything connected to the top of your recirc valve, spaghetti junction and the vac reservoir bolted ontop of coil 4 (leave the n249 plugged in to no error codes and just tuck it away) right down to the little brass nipple on the under left side of the intake manifold.(you have to remove the front engine cover to access this) then run an 8mm vac line from the nipple back up to the recirc and its done
Reactions: Connorg115
CPTHEBOY84
27
SCOTLAND
CPTHEBOY84
27
SCOTLAND
Thing is theres 2 nipples under the intake .. 1 goes to the pfr and theres another next to it with a tpiece on it .. thats where the confusion is coming from i will post pics tomorrow . Thanks for the reoly mate
CPTHEBOY84
27
SCOTLAND
Ok so the rear nipple has pipe of it to the fpr and the front 1 comes off th nipple and goes to th n249 and n112 hoses . So i leave the fpr hose and just run my new hose to th dv off of the frknt nipple ?
Reactions: bigT's lcr
bigT's lcr
Feb 27, 2016
1,133
677
Leeds
Ye just be careful when removing the pipe from the inlet nipple as it can be brittle. Id slice either side vertically with a stanley 1st
Reactions: CPTHEBOY84
CPTHEBOY84
27
SCOTLAND
This is what i have .. so take the small blue hose off and run new hose straight to dv an then remove the vacuum reservoir?
Sent from my SM-G950F using Tapatalk
bigT's lcr
Feb 27, 2016
1,133
677
Leeds
Cut these 3 hoses ? And plug the smaller 1 with a bolt ?
Dont know about this. All i did was disconnect all pipes from n249 ( recirc to valve to vac reservoir to valve to inlet) then run new pipe from nipple to top of recirc
CPTHEBOY84
27
SCOTLAND
If the blue one is from the n249 then yes.
Blue hose goes into the mish mash of hoses under the metal plate . The other is going to fpr .. i think ive got it worked out now after studying mc funbots post and pictures of how he done it . I just wasnt sure as people said there would only b 1 nipple and on the left side of inlet mines on the right side . Just gona go grab some 8mm fuel line and tackle it . Your helps been appreciated mate thanks alot
CPTHEBOY84
27
SCOTLAND
1 of them goes to vac res other to the dv the small 1 is sai/egr . Days in his (how to) to put a bolt into the sai/egr
bigT's lcr
Feb 27, 2016
1,133
677
Leeds
Whats your engine code mate?
