whatsort of moddin is required its probably quite simple but have just bought it so would just be nice to know
yep i have the same one as peachy, well worth it!
are you both using the cone that came with it???
only thing is i have the universal ic which uses the standard pipe work!
will see seems like a great price!
my cone is a bit of a beast
O/D top 160mm
O/D Bot 140mm
Length 150mm
what you recon will it fit??
Will i still be able to you this if i have still got the standard Intercooler??
No pipework in the way?
Prob a silly question:redface:
Will this jetex filter fit in the gap? what size is the pipe 70mm?
if you want it to fit in the same place mine then your filter may be a bit to large,best thing is just to try it mate an see
yea mate no problem,when i had the filter low i just cut about 50/60mm off the end if you want it low with a std intercooler
