pee81
I had a little bump today ended in a bent wishbone and bent steering arm. I got the wishbone off but cant remove the damaged bottom ball joint or the ball joint at the end of the steering arm. I started to loosen the bolts and got so far until the whole ball joint started to turn before the nut came off the rusty thread. I presume its cause they are nylon nuts and should be removed with an impact gun. Is this correct and is there any way of removing them at home with the usual tools? thanks in advance if anyone can help.
