New 1.9tdi Leon Stylance Help
leapy
60
N.IRELAND
MY LEON HAS 3000MILES ON THE CLOCK AND HAS STARTED TO JUDDER AND JERK SOMETIMES WHEN YOU PLANT IT AFTER CRUISING AT 60 .DEALER SAYS NO FAULTS PRESENT.ANYONE GOT ANY THOUGHTS?THANKS:confused:
leapy
60
N.IRELAND
THANKS FOR REPLYING.THE CLUTCH HAS NOT BEEN REPLACED.WHEEN IT JUDDERS IT IS AS IF THE CAR IS RUNNING OUT OF DIESEL.:confused:
bjh1112
Had The Same Problem
My Leon had this problem, it actually requires an ECU software update - at least thats what my dealer done.It effects the VAG 105 bhp engines. See your dealer and tell them to update it.
leapy
60
N.IRELAND
Thanks for the info. Had the car back at dealer today,the mechanic drove the car it did'nt judder but he rekons it's the flywheel.Have to go back next week for it to be fitted so i will ask about ecu updates.cheers for the help.
Xe
Take it into your Seat dealer, as I bet there will be a software problem. They can update it easily, and it will not take long either.
Steve`o
It sounds like egr valve judder. Have done many downloads to cure this.
Steve`o
Was supposed tp put, have had this fault loads of times on different cars, carried out flash update/programing and this has cured the problem
leapy
60
N.IRELAND
going into the dealer on wednesday for a new flywheel asked about updates.they said they will have a look then. thanks to everyone for the help i will let you know how i get on.:confused: :confused:
leapy
60
N.IRELAND
new fly wheel fitted on wed no updates done .car seems to judder slightly in second gear worse in fourth and just as bad in fifth as it was before flywheel was changed.?????????????
Steve`o
Did they change the clutch plate and release bearing as well??
Steve`o
I changed a flywheel recently for the same problem. Also changed the the complete kit inc release bearing. We thought at the time whilst the box was out best to change the whole assy. If you say the problem is still there, go back to the dealer and get tem to roadtest it with you.
a4sline190
My wife recently bought a Leon Stylance TDI with the 105 bhp engine and it seems to do the judder thing after cruising at about 50 - 60 then accelerating, for those of you that have had this issue, did the ECU software upgrade resolve the issue or was it the clutch issue, sound more like the ECU to me but your thoughts welcome.
Thanks in advance.
leapy
60
N.IRELAND
The software update solved my problem even though at first the dealer said none was available.apparently a pulsed signal was being sent to the egr valve but only sometimes and seat uk didn`t know why. hope this helps
a4sline190
Thanks a lot, I will contact my local dealer on Monday, hopefully they have dealt with a few of these issues so will upgrade the software initially to see if this resolves the issue.
Nov 2, 2006
1,241
Annaghmore
bebo.com
I have the 105BHP PD TDI, after frw days noticed a njudder in 5th gear at 1500rpm and was very definate, they took car in and changed clutich and flywheel, no more judder, although i do no have a hesutation but only ehile doing very steady rpm/speeds and get a momentary drop/loss of power for a split second, cant pinpoint it though. I have a BKC engine on an 05 Toledo.
