Phantom3110
Hi all
Over the weekend i fitted a new cam chain on my 1.2 12v AZQ 03 plate ibiza...
Fitted new chain, tensioner and runners, i also fitted new bosch coils packs, the car run sweet as a nut, i've done 22 miles and while driving the battery light and seconds later the oil light came on and the car warning alarm started bleeping i immedietely pulled the car off the road, popped the bonnet and found the crank pulley had come loose (was threadlocked and tightened to the best i could as i dont have access to air ratchets)..
I tightened the pulley up with the intentions of going straight back home which was a mile and a half away.
Turned the ignition key and the car just turns over and wont fire up, ive got a spark the cams are in time with no.1 cylinder tdc. so it has not jumped at all.
I even disconnected the earth for 2 hours in case the car went into some sort of safe mode but still nothing.
Any thoughts as at the moment the car is a expensive drive way ornament..
oh and the crank pulley bolt was 3/4 sockets you will probaly need that pulley tool as it was hard work to undo it, and lastly there was about 23 different sized bolts (including crank bolt) holding the cover on watch out there was one hiding inbetween the water pump.
