new dude on the block.
Ian Tate
18
leeds
hi all.
well I'm not new to seat of VW and had many 1.8t and cant get enough.
so I decided to buy another and spend some cash on making this one to keep, not like all my previous just run about daily uses.
I have a 2004 seat leon Cupra 1.8t auq.
so I bought this totally standard with no mods at all very clean but with no paper work other than a full v5 drives great no lights on dash.
so I went to work full service all filters and oil change and some nice NGK plugs.
smoke test found few leaks so replaced with new blue silicone hoses and clips.
the biggest leak was from the driver valve. replace with forge recirculating one.
few days after started a small coolant leak replaced the temp sensor and gasket cheap fix but better mpg.
I then went to replace the air box with an enlarged k and n induction filter and samco turbo induction inlet hose.
as always I went to see my good pals at Tony banks custom exhaust in Leeds.
Tony also does a great job and yet again built me turbo back custom system and boy does it sound great. aswell as replacing a lamda sensor for me.
I'm not coming to a sticking point as I'm needing all the necessary deletes doing as I really want to put a billet hybrid on it and shortly as well as many other mods.
also I have a back door lock that will not open at all and in need of replacing.
so aswell as saying hi to everyone, if you can advise on a garage that ca do the correct delete and replace my lock with out pulling my pants down that would be great.im in Leeds so anyone about??
thanks again
Reactions: bigT's lcr
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,133
677
Leeds
hi
is it sia and n249 I'm unsure what is needed and looking for advice also.
I see your in Leeds too maybe you can point me in the right direction to a good garage.
thanks for the help.
Did my n249 on saturday and ive got plenty of 4mm vac pipe left so if you dont mind purple pipes i can do that for u?
bigT's lcr
Feb 27, 2016
1,133
677
Leeds
Or if you buy some the colour you want. Its pretty cheap from auto silicone pipes on ebay
Ian Tate
18
leeds
that would be brilliant thank you.
I have a few meter of 4mm vac pipe but thanks you anyway. let me know when your free like cheers again much apreciated.
bigT's lcr
Feb 27, 2016
1,133
677
Leeds
Busy today lol. Im in tinshill so not far mate. If you drive up to me on thursday at 5.30pm il get it done for you pal.
Jimbobcook
5,641
2,189
Welcome to the forum,
Looks like your already being taken care of with regards to one of your questions :)
We have a meet happening in Doncaster on the 28th April if you fancy it? Lots of car chat to be talked about. If it's something you'd like to part of (we don't bite) here is the thread if you want to make a post there suggesting you can make it I will add you to the Meet chat we have going - https://forums.seatcupra.net/index....er-28th-april-2019.449612/page-8#post-4844567
Have fun!
Ian Tate
18
leeds
Have fun!
hi,
thanks for the invite but I'm away that week but I will def be at the next one tho and the car should be in a bit better state for it too.
Reactions: Jimbobcook
