Just back from doing some runs,verdicts please.
Note- sample rate was down as was getting quite a few comms errors for some reason
Code:
Sunday 11 October 2009 21:04:06
06A 906 032 MJ 1.8L R4/5VT 0003
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME
Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF
1.11 3040 88.14 100 9.8 1.82 0 0 0 0
2.52 3520 106.22 100 12.8 3.13 0 0 0 0
3.85 3920 118.72 100 15.8 4.55 0 0 3 5.3
5.26 4280 130.83 100 9.8 5.96 0 0 3 5.3
6.65 4640 136.25 100 16.5 7.37 0 0 2.3 4.5
8.07 4960 145.25 100 16.5 8.76 0 3 1.5 3.8
9.47 5280 151.42 100 18 10.18 3 5.3 1.5 3.8
10.89 5560 159.72 100 15.8 11.59 3 5.3 4.5 3
12.3 5840 159.97 100 20.3 13 2.3 4.5 3.8 2.3
13.69 6080 164.67 100 18.8 14.39 1.5 3.8 3.8 5.3
15.11 6280 166.75 100 21.8 15.73 4.5 3.8 3 5.3
Code:
Group A: '115 Group B: '031
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
STAMP /min % mbar mbar STAMP
0 2360 96.2 1980 1350 0.4 0.984 1
0.8 2560 142.1 1990 1980 1.31 0.984 1
1.81 2880 144.4 1990 1970 2.21 0.945 0.945
2.72 3120 148.9 2000 1990 3.12 0.891 0.867
3.52 3320 151.1 1970 1980 3.92 0.805 0.805
4.32 3560 149.6 1950 1940 4.72 0.789 0.813
5.12 3720 148.9 1980 1950 5.53 0.813 0.828
6.03 4000 149.6 2010 2000 6.43 0.836 0.844
6.94 4240 149.6 1960 1990 7.44 0.821 0.828
7.85 4440 147.4 1940 1940 8.35 0.813 0.813
8.75 4640 142.9 1900 1910 9.17 0.782 0.797
9.66 4880 142.1 1880 1860 10.06 0.766 0.782
10.56 5080 142.1 1840 1830 10.96 0.75 0.758
11.37 5240 139.8 1810 1800 11.77 0.75 0.758
12.17 5400 137.6 1780 1790 12.57 0.75 0.758
12.97 5560 136.1 1740 1740 13.49 0.75 0.75
13.89 5720 134.6 1720 1720 14.29 0.75 0.758
14.68 5880 131.6 1710 1710 15.1 0.75 0.758
15.58 6000 129.3 1690 1710 16 0.75 0.75
16.4 6120 130.8 1680 1670 16.8 0.75 0.735
17.21 6280 128.6 1680 1680 17.61 0.75 0.727
18.09 6400 126.3 1670 1670 18.51 1.281 0.719
Code:
Sunday 11 October 2009 21:09:26
Group A: '118 Group B: '032
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Idle O2 Adapt Run O2 Adapt
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar TIME -10.1 -10.1
Marker STAMP /min °C % mbar STAMP % %
1.15 2880 20 77.6 2110 1.74 0 -3.9
2.45 3360 21 77.3 2010 3.07 0 -3.9
3.76 3840 24 78 1980 4.46 0 -3.9
5.17 4320 28 78.8 1980 5.78 0 -3.1
6.48 4760 32 77.6 1900 7.09 0 -3.1
7.79 5120 36 77.3 1840 8.4 0 -3.1
9.1 5440 38 76.5 1790 9.81 0 -3.1
10.51 5720 40 77.3 1760 11.12 0 -3.1
11.81 5960 43 77.6 1740 12.41 0 -3.1
13.12 6120 45 78 1710 13.73 0 -3.1
14.43 6320 46 78 1730 15.04 0 -3.1
