Jul 29, 2006
723
cumbria
www.facebook.com
Just back from doing some runs,verdicts please.
Code:
Sunday	11	October	2009	21:04:06
06A 906 032 MJ		1.8L R4/5VT         0003
	Group A:	'003				Group B:	'020
		Idle speed	Air mass in	Throt Angle	Ignit Angle		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
	1.11	3040	88.14	100	9.8	1.82	0	0	0	0
	2.52	3520	106.22	100	12.8	3.13	0	0	0	0
	3.85	3920	118.72	100	15.8	4.55	0	0	3	5.3
	5.26	4280	130.83	100	9.8	5.96	0	0	3	5.3
	6.65	4640	136.25	100	16.5	7.37	0	0	2.3	4.5
	8.07	4960	145.25	100	16.5	8.76	0	3	1.5	3.8
	9.47	5280	151.42	100	18	10.18	3	5.3	1.5	3.8
	10.89	5560	159.72	100	15.8	11.59	3	5.3	4.5	3
	12.3	5840	159.97	100	20.3	13	2.3	4.5	3.8	2.3
	13.69	6080	164.67	100	18.8	14.39	1.5	3.8	3.8	5.3
	15.11	6280	166.75	100	21.8	15.73	4.5	3.8	3	5.3
Code:
Group A:	'115					Group B:	'031
	Engine Speed	Engine Load	Spec. Boost	Actual Boost			Lambda Factor	Lambda Factor
TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar		TIME
STAMP	 /min	%	 mbar	 mbar		STAMP
0	2360	96.2	1980	1350		0.4	0.984	1
0.8	2560	142.1	1990	1980		1.31	0.984	1
1.81	2880	144.4	1990	1970		2.21	0.945	0.945
2.72	3120	148.9	2000	1990		3.12	0.891	0.867
3.52	3320	151.1	1970	1980		3.92	0.805	0.805
4.32	3560	149.6	1950	1940		4.72	0.789	0.813
5.12	3720	148.9	1980	1950		5.53	0.813	0.828
6.03	4000	149.6	2010	2000		6.43	0.836	0.844
6.94	4240	149.6	1960	1990		7.44	0.821	0.828
7.85	4440	147.4	1940	1940		8.35	0.813	0.813
8.75	4640	142.9	1900	1910		9.17	0.782	0.797
9.66	4880	142.1	1880	1860		10.06	0.766	0.782
10.56	5080	142.1	1840	1830		10.96	0.75	0.758
11.37	5240	139.8	1810	1800		11.77	0.75	0.758
12.17	5400	137.6	1780	1790		12.57	0.75	0.758
12.97	5560	136.1	1740	1740		13.49	0.75	0.75
13.89	5720	134.6	1720	1720		14.29	0.75	0.758
14.68	5880	131.6	1710	1710		15.1	0.75	0.758
15.58	6000	129.3	1690	1710		16	0.75	0.75
16.4	6120	130.8	1680	1670		16.8	0.75	0.735
17.21	6280	128.6	1680	1680		17.61	0.75	0.727
18.09	6400	126.3	1670	1670		18.51	1.281	0.719
Code:
Sunday	11	October	2009	21:09:26
	Group A:	'118				Group B:	'032
		Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost		Idle O2 Adapt	Run O2 Adapt
	TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar	TIME	-10.1	-10.1
Marker	STAMP	 /min	°C	%	 mbar	STAMP	%	%
	1.15	2880	20	77.6	2110	1.74	0	-3.9
	2.45	3360	21	77.3	2010	3.07	0	-3.9
	3.76	3840	24	78	1980	4.46	0	-3.9
	5.17	4320	28	78.8	1980	5.78	0	-3.1
	6.48	4760	32	77.6	1900	7.09	0	-3.1
	7.79	5120	36	77.3	1840	8.4	0	-3.1
	9.1	5440	38	76.5	1790	9.81	0	-3.1
	10.51	5720	40	77.3	1760	11.12	0	-3.1
	11.81	5960	43	77.6	1740	12.41	0	-3.1
	13.12	6120	45	78	1710	13.73	0	-3.1
	14.43	6320	46	78	1730	15.04	0	-3.1
Note- sample rate was down as was getting quite a few comms errors for some reason :shrug:
Better MAF readings, but still throwing some correction factors. The change in value in 032 long term fuel trims concerns me slightly.
Have you cleared fault codes recently? If not, could you do so, then relog again?
ok mate will do,aside from those,have just serviced the DV and put a yellow spring in,should i see any difference there?
from the logs i've done am i able to work out what boost it is running? bar/psi?:shrug: if so is there a calc i need to convert?
Right Dave,here's run's i've just completed,
Code:
0.94	3080	97.72	100	5.3	1.44	3	3.8	3.8	5.3
2.04	3400	105.58	100	7.5	2.55	2.3	3.8	3.8	5.3
3.15	3680	111.11	100	9.8	3.67	2.3	3	3	4.5
4.26	3960	122.64	100	9.8	4.76	1.5	3	3	4.5
5.36	4280	131.44	100	13.5	5.86	1.5	3	2.3	3.8
6.48	4560	132.61	100	14.3	6.98	0.8	2.3	2.3	3.8
7.57	4800	138.03	100	15.8	8.08	0.8	1.5	1.5	3
8.68	5080	145.25	100	13.5	9.18	0.8	1.5	1.5	3
9.79	5280	150.11	100	16.5	10.29	3	0.8	3.8	2.3
10.8	5480	153.64	100	16.5	11.31	3	3.8	3.8	2.3
11.91	5720	159.94	100	17.3	12.4	2.3	3.8	3	1.5
12.91	5880	156.39	100	21.8	13.41	2.3	3	3	1.5
14.02	6080	161.25	100	20.3	14.53	1.5	3	2.3	0.8
Code:
0.76	2760	21	78	2080	1.26	0	-0.8
1.86	3160	21	80	2010	2.36	0	-0.8
2.97	3560	24	76.9	1980	3.47	0	-0.8
4.08	3920	27	77.6	1980	4.58	0	-0.8
5.09	4280	29	78.8	2020	5.59	0	-0.8
6.2	4640	32	77.6	1930	6.7	0	-0.8
7.3	4960	35	76.9	1890	7.81	0	-0.8
8.4	5240	38	75.7	1810	8.9	0	-0.8
9.42	5480	39	76.1	1780	9.92	0	-0.8
10.52	5680	42	75.7	1760	11.03	0	-0.8
11.63	5880	44	76.9	1740	12.13	0	-0.8
12.74	6040	45	76.1	1740	13.23	0	-0.8
13.83	6200	46	77.6	1740	14.35	0	-0.8
Ok, that's acceptable now, CFs are not excessive. Long term fuel trims no longer showing a fluctuation. I'd be interested to hear P-Torques's opinion on your logs - fancy pming Will?
In answer to your boost question, take your fifth column in 115 log and subtract 1000. That gives your boost in millibars.
