Right big update, did some logging off my N75 Load and Actual vs Requested Boost
I also tested between my Forge Dv and Standard Bosch DV
I did 2 runs with my Bosch followed By 2 runs with my Forge
All runs were done with even breaks between runs and all runs were tested on the same strech of private test track.
I am posting the the best results from each DV
First of all here is my Excel Sheet of a 4th Gear run with the standard Bosch DV
And here is a Graph showing the Requested Boost vs Actual
Now this is where the fun starts,
During my 2 runs with the Forge DV i went into Limp Mode both times in 4th Gear at around 5360 rpm. But i have been around this rpm figure before and not gone into limp mode with the forge on. Further testing with the Bosch is needed to prove that the forge is at fault.
Here is the Excel sheet of a 4th Gear run with the Forge DV you can see clearly where i hit Limp ****.
I received these Fault codes after going into Limp Mode
18048 - Internal Contr. Module (EEPROM) Error
P1640 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
I dont have enough knowledge to be able to determine why im low on boost and going into limp mode.
Help Please Guys!!!
Thanks Alot
Russ
