st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
here is the VAGCOM report from my car and its showing some faults. can any one expand for me?
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 NJ
Component: 1,9l R4 EDC 0000SG 9810
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ8R022421 SEZ7Z0G3885709
1 Fault Found:
17568 - Manifold Temp Sensor (G72): Short to Ground
P1160 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AG
Component: MABS 8.0 front H05 0002
Coding: 0002238
Shop #: WSC 06402
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 00012
Shop #: WSC 04767
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 923 G
Component: KOMBIINSTRUMENT VDO V02
Coding: 00405
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00017
Shop #: WSC 04767
Address 56 -------------------------------------------------------
Controller: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
Cheers Steve
Both are intermittent codes meaning they were set at some point but at the time of the scan, they were no longer present. I would clear the codes and see if they return unless the car is still under warranty. Then I would leave them for the dealer to see.
The temp sensor intermittent short to ground could be the sign of a temp sensor beginning to fail or the wiring between the sensor and the ECU chafing on some surface.
The other error may be a result of the temp sensor error.
many thanks for the help i found today that it was one wire on the map sensor that had rubbed through. so after re wiring the map sensor all seems to be good
