New to VAG-COM Extremely confused
GWalkaa
I have to say I think VAG-COM must be one of the most confused subjects ever. I'm nowhere nearer clarity on the subject after hours of searching.
All I want is to be able to find faults and see them then clear them simple. I have a 2003 LCR 210 and I was considering buying a eBay cable. Can I then download the lite version from Ross-tech then register it later?
GWalkaa
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
I think the lite version gives limited fault code decoding, if you ever plan on doing modding in the future, I would suggest getting the latest full version. I know it's circa £250, but I think that's reasonable for a lifetime of "knowing" what's wrong with your car.
BeartheBruce
Ross-Tech, LLC
Apr 23, 2006
527
Near Philadelphia, PA, USA
As a member of the staff of the creators of VAG-COM and VCDS (Ross-Tech, LLC in the US), perhaps may I be of some help.
For a 2003 LCR, you can purchase a KKL style interface that is compatible with our VCDS-Lite product (sometimes still marked as VAG-COM 409 by some flea-bay vendors). One of our distribs in the UK sells a compatible wire: http://www.gendan.co.uk/product_VAGUSB.html
You can run VCDS-Lite in shareware mode - not paying Ross-Tech anything. If you find you need more advanced features from VCDS-Lite, you can buy a license from Ross-Tech for $99USD.
If you want a full system as james.l suggested, you can contact our UK distribs or you can go to our web site and purchase in our shop.
GWalkaa
BeartheBruce i was hoping you would chime in for a clear bit of info. As my car is the 2003 i will purchase the cable then upgrade if i need to no need for the full fledged system for my car i don't believe.
Thanks all GWalkaa
GWalkaa
BeartheBruce
Thanks. could you just confirm that with the VCDS-Lite service i can scan and find, clear fault codes but i cant auto-scan unless i purchase the license?
GWalkaa
GWalkaa
Okay, could you hit me up with a link to buy the license for the right product?
GWalkaa
GWalkaa
The VCDS-Lite Registration/License can be purchased in our web shop. The item is listed under Enthusiast Systems as VCDS-Lite Software Registration - $99USD
Thanks for the links, so where can i get a cable that will work with the VCDS-Lite latest version. Can i get one from Fleebay? Those are okay arent they to work with the shareware version, would i later be able to register VCDS-Lite and still use a USB cable?
GWalkaa
GWalkaa
Well for the sake of £10 and for it actually working I think I will order it from the supplier. I've heard many stories about them not working with VCDS-Lite, just the 409 etc.
Thanks for all the help!
Gwalkaa
GWalkaa
Right so i purchased the cabke from Gendan, the KKL one. I have installed it following the instructions they sent on both a windows vista 32 bit and a windows 7 64 bit computer tried both ss standard tried both running as admin no luck. I have the port setting to COM1 and have tried all 1-4.
I cant for the life of me get it to work. HELP!!!
GWalkaa!
BeartheBruce
Ross-Tech, LLC
Apr 23, 2006
527
Sorry for slight thread hi-jack...
BeartheBruce, will the registered version of VCDS-Lite allow me to do a throttle body reset on a 2003 Leon Cupra R?
The registered version of VCDS-Lite will allow you to use all of the Basic Settings and Adaptations. So, yes, it will....
I make the assumption that you are already running VCDS-Lite in shareware mode, having full communication with the engine. If not, make sure your set up is capable of this first before buying the license for the full VCDS-Lite. Licenses do not make the product talk to modules...... licenses unlock the restricted procedures.
Gnollins
Bosh!
Jul 24, 2006
406
Yarnton, Oxfordshire
Thanks for the response!
I'm able to read fault codes etc so I think my setup is working.
Will buy the full license on pay day :)
