STOCKY said:
The power is unreal and never stops! Reving the whole way to about 5000rpm:blink: and still pulling strong with more to go!
Have to agree there, top end pull is unreal :-o
spaniels fr said:
Now you wont go lightly on them brakes will you steven? :
will i B:censored: ox , mine gets an awful abuse , 18.9mpg , such an awfully high number lol,. more injection quantity required dan, theyll get a few 100mls of nicey nicey , then itll be back to normal
@ grant , yep goes well , but more is better , roll on vnt20 (sometime)
Pardon my ignorance but whats a vnt20?
And i thought 18.9 mpg at 130 was very good.
:rolleyes: :redface: :headhurt: ah that thing that steven also wanted;) have you got my cheque yet mike?
Does that mean once thats fitted that i will have the most pwerfull mk4 tdi on the site?:funk:
Stephen doesnt hang around and your not getting it done till april! 3 months
Whos going to win:p
Ill keep stiring!:cartman:
Whos going to win:p
Yep but he's spending alot of money on his gauges and he may be getting new suspension. Anyway if he does get the turbo he'll need to come back over to Jbs to get CC3.:p
You too should be spending alot of money on gauges! Worth a thought mate if your going to all the trouble of big turbo, temps and very important and then boost to make sure everything is working as it should!
Already got the suspension sorted I do believe!
Not taking anything away from you mate but all the little things need doing too ie gauges but! You have balls for taking it as far as your gona, alot of ££££ but will be super fast and Ill hopefully get a trip over to test it!;)
ive just worked out i have hit a wall with the big turbo thing , but its ok nothing major , yep i must concur dan youll have the most powerfull mk4 diesel 4 a while,
not that it'll be the quickest along a road if it has corners , diff , diff, diff,
Im gonna get a boost gauge and oil temp gauge fitted when its getting done, just not as exspensive as the ones he's getting.
What wall is this?
no no plenty more where tahta came from young spaniels ,
one of the gauges i bought is 2. bar boost, mines 1.6 something at the min, , most big turbo tdi's run 2.2 2.3 bar , hence the prob , i take it these figures quoted are absolute , il have to see nearer the time .
See here mate. taken from allards site.
" All these turbos are built with a 360 degree uprated thrust bearing and balanced to the highest standards. Upto 2.25 (34psi) BAR capability with optimum performance"
