What is the engine code? Those engines are fairly strong. What mileage and condition, well serviced etc. How did it die? Rod through the block or blown piston crown, head gasket?Could it have been a hybrid fitted without mapping?
Fish
the 110 bhp engine blew?what is the engine code? Those engines are fairly strong. What mileage and condition, well serviced etc. How did it die? Rod through the block or blown piston crown, head gasket?
Turbo sounds like a reasonable suggestion. Your old turbo gave up, didn't it? Was it missing any fins or bits that may have weakened the engine.
Turbo control mechanism failure?
i took this graph as my engine with brand new turbo fitted blew up:
was it the turbo failing that took the engine out? as there seems a boost spike at the point when the engine went bang.
Telling by the graph it seems like you had quite some oil left over in boost piping system/intercooler.
The requested boos it at ambient but suddenly the engine rpm rise very quickly without change in requested boost (change in throttle position).
This leads me to the conclusion that oil was still in the system which got "active" after the first bosst period, sucked into the engine, causing it to rev up and generate the huge boost spike which then killed the new turbo.
You so to say had a engine runaway from improper cleaning out all hoses and the IC before installing the new turbo = user error.
BR
Alex
What state is the engine in?
The warrany people will probably want proof of fitment by qualified or competant technical person and testing of oil properties and all that before they will honour the agreement if everything coincides with their criteria.
