Does any know to find out which AC gas my car uses 2014 i read it could be either old or new. Any way to find out? Also an still stumped on the cause of my issues
Those blocks are nothing to do with the amount of AC refrigerant gas in your system.
The car can't tell you how much gas you have left.
If you haven't had a re-gas in a few years - then as I mentioned previously, this should be your first 'go-to' for poor/no AC cooling.
Cars AC system's aren't hermetically sealed like your fridge refrigerant so do slowly loose gas over time.
Reactions: d_taddei2
A bit of further investigation I have noticed that the cold air blows much more powerful than the hot, when you turn the dial from 1 through to 6 you notice the difference when on cold. But when hot is selected going through the 1-6 dial you barely feel any air from 1-4, and then at 5-6 it's slightly more powerful but nowhere near how powerful the cold is. So although I believe one of the issues is now AC needing regassed what could be the issue with air power? Jammed flaps? And if so how to fix (they aren't the automatic controls) any advice would be great and much appreciated.
I am no expert, but could it be that air recirculation is selected when the AC is tuned up high? Try setting the recirculation when heating. And also check to see if the cabin air filter has been changed in the last year. They are cheap and easy to to yourself.
Hi all losing the will with the car. Just had a new heater matrix fitted had heat for a whole day although still weak. Driver side blows strong but cold air only. Passenger side blows very weak but with warm (not hot) air. So what's the fix? Because am stumped blower fan? Heater resistor? It's analog controls not digital.
Hello had an update. Apparently the flaps aren't working correctly and garage have stated they need replacing with dashboard having to come out. It's analog not digital. Does anyone have any info on this? And parts needed and where to get them any information would be great it's been absolute nightmare
Even though you have 'analog' controls - the flaps are still servo motor controlled. These servos and their levers can get stuck or break over time with lack of use.
You could try cycling them from hot to cold and back several times, and face to feet etc. This 'fixed' my previous Audi which suddenly went cool on one side.
Depends on which flap is stuck/broken - I think there maybe one you can access without dash removal - try searching on youtube for heater servo motor fix.
