no hot air only warm
kr1s77
203
Birmingham
hi guys, i'm not getting any hot air through the vents only warm air. i've flushed the system and changed the thermoatt and cts. all the pipes are getting hot. i've done the basic setting setting on vcds to rest the flaps. i've taken off the lower panels and on the drivers side the lever works to chge the direction of air but on the passenger side i don't see anything moving.
this is a pic of the passenger side, is the round red thing supposed move to let the hot air through? it moves when done through vcds basic settings (Hvac).
[/URL][/IMG]
thanks.
kr1s77
203
Birmingham
i also scanned it and got this error
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
i have cleared it and it hasn't come back yet
mty12345
3,771
475
bristol
Does anyone have a diagram of the heating system please
Couldn't find a diagram of the whole system for you, but according to elsawin that fault code is for the potentiometer (G113) on sensor (V71) which is item 23 in the diagram below. Might be worth checking the wiring to it.
[/URL][/IMG]
15 - Thermosensor fan -V42-
q Removing and fitting → Chapter
16 - Air conditioner with evaporator
q Dismantling and assembling → Chapter
WARNING
The air conditioner should be removed only when the refrigerant circuit is empty.
17 - Fan control unit -J126-**
18 - Fresh air fan -V2-**
19 - Central flap servomotor -V70-
q With potentiometer -G112-
q Linkage lever, colour “green”
20 - Footwell area vent
21 - Temperature flap servomotor -V68-*
q With potentiometer -G92-
q Linkage lever, colour “black”
22 - Condensation drain:
q Checking → Chapter
23 - Dynamic pressure air flap servomotor -V71-*
q Activates the dynamic pressure air flap and the fresh air /recycled air flap
q With potentiometer -G113-
24 - Thermosensor - fresh air inlet channel -G89-*
kr1s77
203
Birmingham
Gonna try and change the matrix this weekend. Do I need to drain the air con system?
Sent from my SM-G920F using Tapatalk
kr1s77
203
Birmingham
UPDATE: i changed the matrix on the weekend and i now have heat again. its a pain in the arse to do. i tested the old matrix and the bottom half was blocked and not get any flow of hot water. the new matrix was bought from ECP, the connections leaked, i changed the O rings but they still leaked. So i got rid of the plastic elbow connections and cut the pipe and extended them and fitted them directly to the matrix outlet. well it works now and enjoying the heat in the cold mornings.
