I have a Nokia CK7W kit that previously was fitted professionally and hardwired in to the existing H\U wiring. (Didn't use any connection blocks)
I am transferring the kit out of my old Cupra, to put it in my LCR.
So having now disconnect it all I don't want to go down the route of cutting & splicing wires when I reinstall the kit in to my other car.
Trouble is also, I'm wondering if the previous installer has cut or modified the existing Nokia kit wiring when he hard wired it in.
From the Nokia kit, I'm left with a cream coloured 15mm flat connector, and 3 wires ,a black, a blue and a red wire with metal plug in connectors. (and obviously the Ariel lead, button switch lead too) Does this sound right??
Both head units are Aura's, but the old one (from a 01 LC) was the cassette\radio type, and the new one (from a 05 LCR) is a CD\Radio. I had a CD Changer with the old unit, so on the back of the old H\U, is a blue,green and yellow block plugged in to the top connector, a black block in the middle, and another block at the bottom.
The blue green and yellow blocks are individually connected together. The blue one being the CD changer connection I assume, but I'm not sure what the yellow and the green blocks are for, so for now I have left them plugged in to the old unit.
Do you think I can get a wiring connection kit for the Nokia CK7W (as long as I have the original connection blocks and leads from the Nokia of course)
I hope this doesn't comes across to confusing!
