gwerdy
9
Right where do i start...
Window packed up on drivers door, struggled getting the door interior off to get to the window regulator which was broke. Temporary stuck the window up once i got it out of the door put the door card back on so i could use the door once i got home to order the regulator repair kit. Except now the door is unabled to be opened inside and out and to top it all off it now wont start and the radio is in safe mode
Can any one help????
wow what a crap day huh!! i had to replace my window reg on my old leon and while it was disconnected my door didnt lock! maybe linked (maybe a good idea to just connect the bust window reg and see if the door locks work) You can just do what i did and drive it around with the door card off mate, just pull the door handle rod to unlock. Batterys die very quickly these days, so grab a volt meter and test also check for loose battery terminals. good luck.
If you've haven't gotten it sorted keep the thread going. I replaced my windo regulator once it does give alot of problems to reinstall but tgeres a way.
Bought a leon cupra 2000 reg to find there was no window system behind the metal panel at all just a block of wood holding the window up lol
Bad times
I've got a leon to break up so if you get stuck with anything give me a message and I'll try to help you out
