joe_thompson
41
We basically my cars not boosting right, it seems like it drops off boost, and also doesn’t seem to boost up for what it should (18psi)
I can also smell fuel when I put my foot down for, this is only if you put it down for over 15/20 secs. I have no idea what it could be :S
I know iv got a blowing inlet manifold, iv just picked up a new gasket and studs so should sort that out tonight but surely that would cause it would it?
My cars a 02 ibiza cupra, cat back miltek, forge D/V, pipercross induction, P-torque remap, phampton boost gauge.
Any ideas?
I've heard the smelling fuel before... when's the last time the fuel filter's been changed?
ALSO i went to a meet late nite and a kind chap called gavin hooked my ibiza up to his VAG COM this is what it came up with.
VAGCOM
Address 01: Engine Labels: Redir Fail!
Part No: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
2 Faults Found:
17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :)
P1560 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 6K0-959-291.lbl
Part No: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
2 Faults Found:
00853 - Loudspeaker(s); Rear
36-00 - Open Circuit
any ideas?
a friend of mine had the same problem we checked all to fuel lines took the tank out sealed every joint and it stopped for a little and came back again[:@]:censored: turned out that it was the fuel cap it turned out the small hole that was ment to be in the centre that not been drillled right through so he drilled the hole right through and so far problem solved all i can say is get a new cap
well just so happens me dad brought me home a bently one from work soo il put that on tntie see if it makes any differnece, although i dont think thta will be the problem :/
i really dont know what to doo :(
VAGCOM
2 Faults Found:
nice going there!!! ;) looks like some one has been a bit excited at the wheel and down shifted too early!
16486-mas air flow sensor (G70): signal too low...could be making it overfuel maybe...or could just be that the pipercross filter has fooked it...
i had this with mine, i changed the n75 valve and the boost stated holding again.
try that or check out the actuator, mine leaks boost when it hits 15psi
im gona get rid of that piper cross all it does is suck in hot air :/
yee il try that, well iv got me car booked in a PSI http://www.psituning.com
on monday so hopfully they will know whats wrong. although il have a look againa t the weekend. who will i know if its gone?
