Did some research last night for the intermitent juddering a I get from time ti time and found this error with Vag-Com:
17521 Bank1-Sensor1 Internal Resistance too High (Intermitent)
Also, did a couple of power runs and my MAF readings ar peaking at 113g/s, which is a bit low for a stock 20VT.
The multiplicative fuel trim is also of with a value of 24! I'm running lean at high rpm
What sould I do first? O2 probe or the MAF?
Code:
Tuesday 8 July 2008 21:58:04
06A 906 032 T 1.8L R4/5VT 0003
Group A: '003 Group B: '115 Group C: Not Running
Idle speed Air mass in Throt Angle Ignit Angle Engine Speed Engine Load Spec. Boost Actual Boost
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
MARKER STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP
206.33 2160 26.69 100 24 206.73 2240 66.9 1880 1170
207.13 2360 37 100 19.5 207.53 2520 82 1880 1440
207.93 2640 49 100 12.8 208.33 2840 96.2 1830 1720
208.73 2960 56.67 100 8.3 209.13 3160 127.8 1770 1740
209.53 3280 61.94 100 9.8 209.93 3440 130.8 1720 1700
210.33 3600 68.25 100 12 210.73 3760 131.6 1730 1700
211.13 3880 73.81 100 12.8 211.53 4040 133.1 1750 1720
211.93 4160 78.31 100 12.8 212.33 4280 135.3 1730 1720
212.73 4440 86.47 100 15.8 213.11 4600 136.8 1720 1710
213.51 4720 91.92 100 15.8 213.93 4880 136.8 1720 1690
214.33 5000 97.17 100 16.5 214.73 5120 136.8 1730 1670
215.13 5280 103.14 100 15.8 215.53 5400 133.8 1730 1660
216.03 5520 107.83 100 17.3 216.43 5640 130.8 1700 1640
216.94 5800 113.83 100 16.5 217.34 5160 11.3 990 1320
Code:
Tuesday 8 July 2008 22:05:19
Group A: '004 Group B: '120 Group C:
Idle speed ECM Voltage Coolant Temp Intake Temp Engine Speed Spec Load Curr Load ASR Status
TIME 700-820 rpm 12-15V 80-110 C -48-110C TIME 700-6800 RPM 0-399 Nm 0-260 Nm active yes/no TIME
MARKER STAMP /min V °C °C STAMP /min Nm Nm STAMP
226.79 2360 13.51 96 50 226.28 2360 399.8 15.7 ASR OFF
227.59 2400 13.51 96 49 227.19 2360 399.8 13.7 ASR OFF
228.39 2600 13.44 96 48 227.99 2480 399.8 103.9 ASR OFF
229.19 2880 13.44 96 46 228.79 2720 399.8 149 ASR OFF
229.99 3240 13.51 96 45 229.59 3040 399.8 172.5 ASR OFF
230.79 3560 13.51 96 45 230.39 3400 399.8 180.3 ASR OFF
231.57 3840 13.44 96 45 231.17 3720 399.8 243 ASR OFF
232.37 4160 13.51 96 45 231.97 4000 399.8 248.9 ASR OFF
233.19 4440 13.51 96 47 232.77 4280 399.8 250.9 ASR OFF
233.98 4720 13.51 96 48 233.57 4560 399.8 250.9 ASR OFF
234.88 5000 13.51 96 50 234.48 4920 399.8 239.1 ASR OFF
235.79 5280 13.51 96 51 235.28 5160 399.8 241.1 ASR OFF
236.59 5560 13.44 96 53 236.19 5400 399.8 239.1 ASR OFF
237.38 5760 13.51 96 55 236.99 5640 399.8 231.3 ASR OFF
