Wolvotim
218
Shifnal, Shropshire
Cleaned my TB and reset it today then took it for a run and did a log of it
Am i correct in thinking that you take 1000mbar off the reading to give your boost?? If so the reading in red equates to 10psi which i thought is a little high for a standard LC?
Code:
Saturday	6	February	2010	16:19:52
06A 906 032 MJ 		1.8L R4/5VT         0003
	Group A:	115				Group B:	003				Group C:	120
		Engine Speed	Engine Load	Spec. Boost	Actual Boost		Idle speed	Air mass in	Throt Angle	Ignit Angle		Engine Speed	Spec Load	Curr Load	ASR Status
	TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME	700-6800 RPM	0-399 Nm	0-260 Nm	active yes/no
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 /min	 Nm	 Nm
	11.27	2320	62.4	1000	1240	10.36	1320	21.53	43.1	14.3	10.78	1880	399.8	86.2	ASR OFF
	12.47	1840	54.1	1000	1120	11.67	2440	14.56	8.2	26.3	12.07	1560	399.8	115.6	ASR OFF
	13.79	1120	85	1270	1170	12.89	2000	15.72	9.4	21.8	13.39	1680	399.8	156.8	ASR OFF
	15	1320	87.2	1400	1180	14.19	1200	20.08	67.1	12.8	14.6	1280	399.8	158.8	ASR OFF
	16.3	1560	91	1500	1240	15.5	1400	24.42	80.4	12.8	15.9	1480	399.8	162.7	ASR OFF
	17.51	1800	99.2	1610	1340	16.71	1640	30.28	93.7	12.8	17.11	1720	399.8	172.5	ASR OFF
	18.83	2160	127.1	1700	1610	17.91	1920	40.86	100	11.3	18.31	2000	399.8	213.6	ASR OFF
	20.23	2560	130.8	1680	[COLOR="Red"][B]1690[/B][/COLOR]	19.32	2280	58.78	100	9	19.82	2440	399.8	250.9	ASR OFF
	21.43	2920	130.8	1660	1670	20.63	2680	67.22	100	12.8	21.03	2800	399.8	250.9	ASR OFF
	22.65	3280	133.1	1610	1650	21.83	3040	78.53	100	12	22.23	3160	399.8	250.9	ASR OFF
	24.06	3720	126.3	1590	1600	23.14	3440	88.61	100	16.5	23.56	3560	399.8	241.1	ASR OFF
	25.46	4120	127.1	1620	1600	24.46	3840	91.56	100	21	24.95	3960	399.8	235.2	ASR OFF
	26.78	4440	130.1	1620	1610	25.96	4240	105.5	100	20.3	26.36	4360	399.8	235.2	ASR OFF
	27.98	4720	129.3	1620	1610	27.16	4520	112.56	100	21	27.58	4640	399.8	229.3	ASR OFF
	29.19	5000	131.6	1640	1600	28.38	4800	121.61	100	19.5	28.79	4880	399.8	231.3	ASR OFF
	30.49	5240	133.1	1650	1620	29.59	5080	128.25	100	15	29.99	5120	399.8	231.3	ASR OFF
	31.91	5480	136.1	1660	1620	30.9	5320	139.22	99.6	18.8	31.4	5400	399.8	231.3	ASR OFF
	33.32	5760	134.6	1630	1630	32.39	5600	144.64	100	17.3	32.81	5640	399.8	225.4	ASR OFF
	34.61	5920	131.6	1600	1580	33.72	5800	146.86	100	20.3	34.21	5880	399.8	219.5	ASR OFF
	35.83	6080	128.6	1580	1600	35.01	6000	149.67	100	21	35.43	6040	399.8	207.8	ASR OFF
	37.13	6240	127.1	1580	1580	36.23	6120	150.44	100	21.8	36.73	6200	399.8	196	ASR OFF
	38.44	6360	125.6	1580	1630	37.54	6280	154.39	100	21.8	38.04	6360	399.8	196	ASR OFF
	39.65	6480	125.6	1570	1590	38.84	6440	152.47	100	21.8	39.26	6440	399.8	182.3	ASR OFF
	41.16	6640	121.1	1570	1550	40.15	6560	153.72	100	22.5	40.66	6600	399.8	182.3	ASR OFF
	42.57	6760	120.3	1570	1540	41.56	6680	153.89	100	24	42.07	6720	399.8	178.4	ASR OFF
	43.96	5480	11.3	1000	1090	42.97	6760	158.42	100	24	43.48	6320	399.8	0	ASR OFF
	45.17	4800	12	1000	1040	44.37	5040	11.81	7.8	5.3	44.77	5000	399.8	0	ASR OFF
	46.49	4160	12	1000	1040	45.57	4640	11.31	7.1	3.8	46.07	4360	399.8	0	ASR OFF
	47.78	3600	12	1000	1040	46.89	4000	9.86	6.3	3	47.29	3800	399.8	0	ASR OFF
	49.09	3080	12	1000	1020	48.18	3480	8.22	5.5	1.5	48.6	3000	399.8	0	ASR OFF
