Hi Guys, Just got my HTC Sensation so I bought the software straight out and WOW its come on leaps and bounds.
I love the track day plugin that records what your doing plus it logs, fantastic!
Anyone have any idea what MAF and what PSI boost I should be reading in a 278bhp LCR?
I'm using the suggested -14.7 setting for sea level (According to the software) to calculate the boost.
Cant remember what the MAF is pulling but I'm SURE I saw the boost peak for a second at 30PSI which seems WAY too high to me but on full beans in a straight line its between 25 and 27PSI.
MAF Pulls like 186 I think,
Found out today it wasn't logging so I'm going to have to log it when I'm charging down a motorway ramp!
I'd think about 222g/s for 278 using the "g/s x 0.8" calculation.
I'm not entirely convinced how accurate Torque's logging is, it also seems to be worse if you have more readouts visible on the screen, same principle as having VAGCOM only logging one block gives you better accuracy than when logging two or three together, the author says something about that on the website.
Also don't log when running downhill, that skews the readings because the load placed on the engine is less than when on a flat or uphill. Ideally you want to log on a straight road, flat or on a slight uphill slope.
