Sounds good man. Just payed my 45.08. Hopefully be here before crimbo...now to find myself a car is the next task lol...
Sent from my SM-N9208 using Tapatalk
Mine arrived within a week, came from Romania! Good luck with the car hunt :)
Mines just arrived, however i was very surprised to find 17 faults.
Can I tell my dealer that I've used this device and found these faults?
What faults are they? will be worth screen shotting them, then clearing them.
Drive around for a few days then see if they have returned.
the most time you get sporadic fault
sample log from other cas
01 Engine Control Module 1
System description: R4 2,0L EDC
Software number: 04L906021DS
Software version: 7544
Hardware number: 04L907309D
Hardware version: H22
ODX name: EV_ECM20TDI01104L906021DS
ODX version: 002012
Long coding: 11190012032501080000
Trouble codes:
U112300 - Databus error value received
Intermittent
U042800 - Invalid Data Received From Steering Angle Sensor Module
Intermittent
03 Brakes 1
System description: ESC
Software number: 5Q0907379K
Software version: 0371
Hardware number: 5Q0907379F
Hardware version: H31
Serial number: 61334000001787
ODX name: EV_Brake1UDSContiMK100ESP
ODX version: 033001
Long coding: 19EE8A92242009750077060941C5249851249000608224F200610060C002
Trouble codes:
B1168F2 - Steering angle sensor no initialization
Intermittent
C102D00 - Tire pressure warning
Intermittent
08 Air Conditioning
System description: Climatronic
Software number: 5F0907044D
Software version: 0705
Hardware number: 5F0907044D
Hardware version: H03
ODX name: EV_ACClimaBHBVW37X
ODX version: 003017
Long coding: 02100104202100011005000000101000
Trouble codes:
P171900 - Function restriction by engine control module
Intermittent
09 Central Electrics
System description: BCM MQBAB M
Software number: 5Q0937084AG
Software version: 0134
Hardware number: 5Q0937084AG
Hardware version: H18
Serial number: 01011414202870
ODX name: EV_BCMCONTI
ODX version: 013000
Long coding: 0B000842424100DB03A04000B10403281000000000000000000000000000
Subsystems:
System description: WWS370 140428
Software version: 0574
Hardware version: 041
Serial number: 140505021100
Long coding: 0BC5FD
System description: Sensor, DWA
Software version: 0315
Hardware version: 005
Serial number: 000000000ZY140974TPU
System description: Sirene, DWA
Software version: 0311
Hardware version: 004
Serial number: 00000000000059716847
System description: G355_FeuchteS
Software version: 0002
Hardware version: H07
Serial number: 20748134
Trouble codes:
No trouble codes found
15 Airbag
System description: Airbag VW20
Software number: 3Q0959655AC
Software version: 0189
Hardware number: 3Q0959655AC
Hardware version: 012
Serial number: 003P4PA1YRVV
ODX name: EV_AirbaVW20TS6VW48X
ODX version: 001116
Long coding: 98CCC000000000005C0000CC008800000065
Subsystems:
System description: SideSensor_Df
Software version: 0887
Hardware version: 008
Serial number: 3576U0000009D248CF0S
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 3586U0000002522CBF0F
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 0148
Hardware version: 111
Serial number: 3516R01149503000000M
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3526RFC2FA503000000J
Long coding: 2D2D2D
System description: FrontSensor_D
Software version: 0149
Hardware version: 114
Serial number: 3556VEA555A03000000G
Long coding: 2D2D2D
Trouble codes:
B13BCF2 - Multiple collision brake No function
Intermittent
16 Steering Column Electronics
System description: Lenks. Modul
Software number: 5Q0953507AC
Software version: 0070
Hardware number: 5Q0953549
Hardware version: 007
Serial number: 26051404221087
ODX name: EV_SMLSKLOMQB
ODX version: 009001
Long coding: 1400
Trouble codes:
17 Dash Board
System description: KOMBI
Software number: 5F0920962A
Software version: 4270
Hardware number: 5F0920962A
Hardware version: 202
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009037
Long coding: 27A412002180260001082A001000000000000000
Trouble codes:
19 Gateway
System description: GW MQB Mid
Software number: 5Q0907530S
Software version: 1188
Hardware number: 5Q0907530E
Hardware version: 127
Serial number: 0002009521
ODX name: EV_GatewLear
ODX version: 011016
Long coding: 030100F40B087300EF0002C8080F00010001000000000000000000000000
Subsystems:
System description: J367-BDMHella
Software version: 8043
Serial number: 4423563403
System description: E221__MFL-PR6
Software version: 0130
Hardware version: H04
Serial number: 000000000A0328050514
Long coding: 002000
Trouble codes:
42 Door Electronics Driver Side
System description: TSG FS
Software number: 5Q4959593B
Software version: 0014
Hardware number: 5Q4959593B
Hardware version: 009
Serial number: 0000102720781
ODX name: EV_DCUDriveSideEWMAXCONT
ODX version: 006001
Long coding: 00100220DE01040000001000
Subsystems:
System description: FOND_FHSG_DRV
Software version: 0005
Serial number: 00000000000002735373
Long coding: 2D0000
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144P
Software version: 1043
Hardware number: 5Q0909144P
Hardware version: 122
ODX name: EV_SteerAssisMQB
ODX version: 010031
Long coding: 8103
Trouble codes:
52 Door Electronics Passenger Side
System description: TSG BFS
Software number: 5Q4959592B
Hardware number: 5Q4959592B
Serial number: 0000103340456
ODX name: EV_DCUPasseSideEWMAXCONT
ODX version: 006001
Subsystems:
System description: FOND_FHSG_PSG
Serial number: 00000000000002743054
Long coding: 350000
Trouble codes:
B122D29 - Lock unit for central locking Implausible signal
Intermittent
5F Information Control Unit 1
System description: MU-E--ER
Software number: 5F0035869A
Software version: 5805
Hardware number: 5F0035869A
Hardware version: 640
Serial number: 24031400010906
ODX name: EV_MUEnt4CLGE
ODX version: 001025
Long coding: 04730300FF00000011110001000000002F0007860000010000
Trouble codes:
76 Parking Assistance
System description: PARKHILFE 8K
Software number: 5Q0919294E
Software version: 0048
Hardware number: 5Q0919294A
Serial number: 39331413201444
ODX name: EV_EPHVA18AU3700000
ODX version: 002024
Long coding: 0011051001
Trouble codes:
Hi been playing with my pro managed to alter flashers to 5 times and get rear lights on with DRL but when i try and alter the stop start it justs says failed this is doing it by the apps and yes i have enough credits any tips on how to get it to work thanks in advance Rick
DAB aerial input gain adjustment.
When altering the aerial input gain (which is 128db by default) do you increase the value or decrease the value to hopefully get a better signal ?
Tried this a while ago and going up and down didn't seem to make any difference to may DAB radio.
I've cleared the faults and drove into work again today. I'll run a scan at lunch and see what shows.
Is there a way to bring back factory defaults on the long coding option? I messed with my door card light hoping to get it to flash between white and red when indicating and now it just doesn't turn on at all...
I'll run a check on my working door cards later which flash white and red and are also red on all modes. I'll give you a run down of each setting if that helps.
Driving different car now so can't check.
Brilliant thanks! I asked you on another thread where you posted the video!
Has anyone managed to get Coming Home/Leaving Home lights working without Auto Lights?
This is Central Electrics 9, then Adaptions THEN 16
I think that's all you need. Match those and you should be OK.
DISCLAIMER - I take no responsibility on those changes you make. :shrug:
You absolute legend! Thanks!
I shall let you know if it worked.
Yeah that worked fine. It would be good to see left indicate for indicating left.
Either way, it's a nice party trick.
