OBDeleven modifications
sean93
Is there a mod on the obdeleven that can start the car up in the same mode that the car is turned off in?
For example currently when i turn the car off in sports mode and turn it back on it started back up in normal mode even if it still shows sports highlighted on the modes menu.
Hughes395
176
Now that I've activated one touch mirror fold. Is there a way to get my windows to do the same?
Sent from my SM-G900F using Tapatalk
paddy6789
1,627
1,082
Preston, Lancs
I wanted this originally but then thought it possibly is a safety feature that it doesn't do so; some people leave windows open on hot days for dogs etc inside the car. You'd want to lock the car whilst still having the window open.
Seat Leon Cupra 290 DSG Black Edition (Alor Blue)
Performance: Racingline OEM+ Stage One Mapping | Racingline R600 Intake | Racingline Turbo Inlet Pipe | Racingline Turbo Elbow | Racingline Muffler Delete | OEM NGK Audi RS7 Spark Plugs | 034 Motorsport Dogbone Mount
Interior: Koonlung K1S Dash Cam with BlackVue Power Magic Pro
Exterior: TRC Front Splitter | Foliatec Exhaust Paint Gloss Black
zedlor
298
123
Warrington
Does anyone know if there's a modification to have the red lights on the doors all day, even when the lights are off (but still on auto)? And make them a bit brighter? I can't seem to find that combination anywhere...
Deleted member 103408
Is this what you are after
Adjustment Door Led Light Intensity
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
Select: max 127
(6)-Leuchte17TFLR SRB3TFL R SR KC3-Dimmwert AB 17
Select: max 127
Originally Posted by ClrDaLane
Door lighting always red
Dont know if its on all day but give it a go.
1. Module 09, 31347
2. Adaptation
3. Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
4. Lichtfunktion A17 = Nicht Aktiv
5. Leuchte16BLK SLB35BLK SL KC9
6. Lichtfunktion B16 = Ambientelicht 3
zedlor
298
123
Warrington
Security access
Access Code 31347
Adaptation
Select: max 127
Select: max 127
1. Module 09, 31347
2. Adaptation
Ooh thanks I'll have a go, one of them looks familiar as I couldn't seem to find one of the settings on mine, but I'll have another go.
^^^ good point, on mine if you hold the lock key down then the windows will close, not one touch but you can remote close and open them.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Convenience window opening / closing is available with long press of either key fob lock or unlock buttons. Thinks it's tunable in incar settings to only operate drivers window or all.
zedlor
298
123
Warrington
Security access
Access Code 31347
Adaptation
Select: max 127
Select: max 127
1. Module 09, 31347
2. Adaptation
It works!
One thing to note though for anyone else looking, if you also have the modification enabled to have the door lights flash when indicating, the Lichtfunktion A17 will already be set to something else (Blinken lights Helphase if I'm remembering correctly), so leave this as it is as don't change to Nicht Aktiv and both mods will work fine together, as far as I can tell anyway.
Webstuff72
481
101
Milton keynes
OK, so now have:
Carbon FIS and infotainment
50kph cornering fogs
No ignition on warning (neither visible or audible)
DRL on/off tickable in lights menu
Is is possible to change the maximum infotainment volume at switch on to less than 5?
Can you please show me where you got the instructions on how to change the speed of the cornering fog lights. Thanks..
have you checked out http://obdeleven.proboards.com/thread/764/coding-adaptations
Regulation of lights or turn corner (Dont have fogs but hopefully this is what you want)
With this modification you can change the speed at which you want them to act the cornering. By default come to 40 km / h.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - static curve light
4 - Sub - Untere geschwindigkeitsschwelle
5 - Change the desired value
6 - Sub - Obere Geschwindigkeitsschwelle
7 - Change value to 60. Default 40 Km / h
where Untere geschwindigkeitsschwelle = Untere geschwindigkeitsschwelle --- updated Lower speed threshold
and Obere Geschwindigkeitsschwelle = Upper speed threshold
Webstuff72
481
101
Milton keynes
2 - Adaptation
Thank you. Greatly appreciated..
Update: Done. Changed to 64km/h (40mph).
Thanks again..
Webstuff72
481
101
Milton keynes
I have just recieved my pro code and further to the above mod, I have tweeked the cornering lights and microphone sensitivity also.....
I modded the Fogs to flash with Main Beam. A definite bonus as I have Cree LED's bulbs in the Fogs..
And I've increased microphone sensitivity as people have told me they find it hard to hear me.
The option is 0 - 22db. So I'm working my way up in 5's.
The hand arrows indicate what is needed to be changed. Pretty obvious I hope.
The dipped wing mirror while reversing and Scandinavian lights, I just did using the apps.
Would like to get the cornering lights to work without having to have the dipped lights on. So still looking for that.
Love the OBD11. Just make sure you take screen shots as you do it. So you can always go back if something doesn't work...
Reactions: Bruno.73
Webstuff72
481
101
Milton keynes
Wastedagen all changes you make via OBD11 is recorded in the history section, check out http://obdeleven.proboards.com/thread/97/history so you can see easily what and how you changed stuff.
Also you should take regular backups http://obdeleven.proboards.com/thread/1382/backup as this will show you all the long coding changes you have made as well as everything else.
Thank you for the info and links... I'll check them out now.
I'm still old school. I screen shot everything... Lol
I've bricked a phone or two. No problem just reinstall Android... I don't fancy bricking my car...
Fully understand. Good thing all your changes are stored on obd11 servers so if you loose/break/disable you phone/tablet/other devise you can just log back in and there it is. I also save all my backups to excell so i can compare and double check changes.
Sent from my SM-G920F using Tapatalk
Webstuff72
481
101
Milton keynes
Good idea thanks.. And didn't know about the servers either. That is the ultimate fail safe then..
