Odd TCS issue
hectic
Hi,
Got a weird intermittent TCS issue with my Seat Leon Cupra TDI (04).
Twice now, whilst driving, the TCS light has come on the dash (the triangle with the circular arrow around it), and I have experienced reasonably severe juddering, especially when trying to accelerate in a high gear at (relatively) low revs.
I have had it VAGCOMed twice now and on both occasions there are no errors at all.
N.B.: Prior to the light coming and juddering starting I was experiencing some hestiation, like you might get if you had fuel contanimation (or were just running out of fuel).
Any insights would be gratefully received.
H
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Read measure value block 01 on Vag com, te last figures on the right (or the one that say airflow meter readings). it should read from 0 (no strain on the engine) to 255 (engine under full load and turbo on full boost) if it does not reach 255 there's a fault with the meter.
hectic
Thanks, f*cking awesome reply, I will tell my pet mechanic.
H
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
cant see it being that much , cost me £65 last time (£25 diagnosis £20part £20 labour )
Ive diagnosed it £Free
will get prices of TPS later
it gave me a code 00283 front left wheel speed sensor (G47)
also 012 fault in circuit
any ideas if thats just sensor gone or wiring too
cheers
p.s mark how did the carbonio go
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Speed sensor could explain the tcs light but not the juddering and hesitation, however its a piece of p1ss to check the speed sensor function on measure value blocks on vag-com:
Address "03 - brake electronics" then either value 00 or 01, this will give you the speed reading of all 4 wheels.
On earlier models the tcs/esp was effected by the function of the MAF function because it cut off the fuel supply in order to prevent wheel spin. If the MAF is not sending a correct reading then the ABS and engine control units cannot determine how to cut the fuel, dab the brakes etc so it bring on the TCS/ESP light and limits its function.
Andrewcupra TDI
Apr 30, 2008
3,282
cheers
just rang seat @£48.19 +vat
TPS £44.33
is it worth sticking with geniune
i think last time it was changed it must have been with an aftermarket one believe it was from europarts ?
cheers
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
No mate, if any lights appear when braking then there's a problem, Normally a low fluid level.
The only time any tcs/esp lights should come on is when you attempt to spin the wheels and the tcs/esp intervenes or when you loost traction then it should flash until traction has been re-gained.
hectic
Hi,
Still getting this vexing TCS issue. VAGCOM shows a fault with the:
ASR FRONT MK60
Can anyone say if this is an ABS sensor issue?
H
hectic
Similar to this:
Address 03: ABS Brakes
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0013313
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
hectic
Appreciate the reply, many thanks.
This is the complete fault reading:
Address 01: Engine Labels: 038-906-019-ARL.lbl
Part No: 038 906 019 KG
Component: 1,9l R4 EDC 0000SG 5342
Coding: 10002
Shop #: WSC 06402
VSSZZZ1MZ4R085901 SEZ7Z0D2392745
1 Fault Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-00 - -
Readiness: 0 1 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Coding: 0022017
Shop #: WSC 00001 001 00001
1 Fault Found:
