Off foglights off!!
robbo83
Im possibly about to win the stupidest question trophy, but...
I cannot turn the foglights off!!!! :cry:
Ive turned every dial and pushed every stick. No lights appear on the dash to show any lights are on.
If the dial is set to off theyre on, if I move them to main and pull once theyre on, and if I pull it again I get rears aswel as front fogs.
Any Im doing wrong or is is just dodgy wiring??
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Have you pushed - not turned - the dial into the dash? If so, you may have a dodgy switch, so best get it to Seat for a quick check.
robbo83
Yeah Ive pushed the dial in and the lights go out (thanks to the reflection off the car in front), but when I release it it pops out and the lights come on again
robbo83
Joy. Go Go Gadget warranty.
How many different positions does the dial have then?
I assumed you pulled it out once for front fogs and out again for front and back. I didnt realise you could push it in from its standard position
TimBarratt
435
Blandford
You should only be able to pull it in or out with the lights on if that makes sense. With the lights off you shouldn't be able to pull it out. Also as you turn the switch to turn off the lights, the switch should go back in.
robbo83
Yeah thats right Tim, it seems to push in or out in once its "on", but once you switch them off, they remain....on!
Cheers for the price info Arnolfini, hopefully the guys at the garage will be easily persuaded with the offering of sweet sweet nectar :cheers:
