Right here we go, sorry for the delay the battery on the camera was flat then i had to go christmas shopping lol, i will give a
guide after the pic's.
This is the over all pic you can see the one from the rocker cover and has the "T" to the block and the other pipe goes to the TIP.
This is the pic of where the pipe goes in to the tip, my car is an LC but i expect the LCR has this in the same place.
The elbow going to the block,.
This is the conection for the block under the inlet manifold.
The conection to the TIP
Now you know where all the pipes go just remove all the OE pipes, make sure you know where you are going to mount the tank and plan the pipe route.
The main
problem i had is that the tank inlets are a diferent size to the engine inlets so i got some reducers from 19mm to 16 mm and used them just before the tank you can see them in the over all pic.
The TIP conection is easy enough 19mm elbow goes straight in, the block conection is easy aswell all you need to do is remove the elbow you do this by pulling the clip arrowed in the pic once it is out pull the elbow towards you it is now alot easyer to put the new pipe
on then just replace push the clip back in and do up all the conections.
Although it works it is not that nice to look at i am constantly on the look out for better pipe work.
I hope this is of some use any questions please ask.
