speedsix
Leon Cupra R 225
Oct 30, 2004
825
Anyone else doing this? 10k seems an awfully long time between changes.
Mine had a change at 39k, then the 40k service minus a change, now on 46k.
Change the oil as often as you want, the more the better to a certain point. Obviously it wouldnt be worth doing it every 1k but no harm in changing it every 5k etc. Depends if you got the time and money :D
Use motul 15w50 300v if i were you, its about 60 quid for 6 L from Bill.
I spent alot of time deciding, and i will stock up very shortly on it.
speedsix said:
will 10w40 magnatec be ok?
iv used it fine no complaints..20quid ish for 4.5l
would have got the Vag special by castrol though if i had the chance, cant remember wot its called longlife or something
wouldnt bother changing under 8-10k though not unless u spend alot of time at the red line...seems a waste of money
every 10k for me
i change my oil every 5K, gotta b worth it. I use quantum synth gold (fully sinthetic oil) Got it from the dealer, think it was 5.5L for £18, VW rated
