oil in intercoolers
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
As the title says i have found oil in all the pipes and intercoolers would this indicate an oil seal in the turbo has gone, the car is not burning oil its just in the pipe work.:confused:
Ronin225
4,652
22
Worcester
when i changed my intercooler pipes there was a little bit of oil in there but have seen many threads saying its nothing to worry about
Ronin225
4,652
22
Worcester
ive been through there a few times but not noticed any other leons there. in fact might be passing through tomorrow helping a sparky friend for the day since i got laid off again.
but a cup full is a lot, when you took the pipe off did it pour out??
might be worth just poppping the one off the charge pipe and have a look at the state of that
Ronin225
4,652
22
Worcester
mine had about a half shots worth counting both ends so about 15ml or something but it is a low point so would gather.
the seals as you said maybe on their way out but you would need to talk to someone a bit more familiar with these engines
Ronin225
4,652
22
Worcester
probably just a good idea to keep an eye on oil levels. only a small amount but if you check regularly you should notice.
i hope that the k04 will be arriving in hybrid form:D
Ronin225
4,652
22
Worcester
lucky git, i am leaving mine for a while yet, its only done 27k but when you get it done we will have to meet up and go out for a spin.
what kind of numbers you hoping to see
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Phil I had alot of oil in my SMIC's and IC pipes as you might have noticed.
I probably had a cup full out of the last SMIC before the throttle body. Since then I have done 20,000 trouble free miles
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Ronin, i'm looking for 270/280bhp as i use it for work every day so need to keep it reliable.
Willie, that's about what came out of my single cooler when i put your LCR ones on, asked mechanic about it today when he did my mot and he also said not to worry.( Failed, worn brake pipe and rear brake light)
