Oil Leak
dirtbiker
274
Southampton / Nottingham
Hi all,
As some of you may know I replaced the head on my 1.4 (AEX) last year.
I noticed the oil pressure light flickering on (very occasionally) recently and thought I better check the oil level just in case. I found that there's a bit of oil on the side of the head:
Am I right in thinking this is probably the rocker-cover gasket? Is it just a case of it not being seated correctly?
Cheers :)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
just above that bolt holding the timing belt cover i can see a leak :) = rocker gasket - cheap as chips so id just throw the old one anyway
and when you clean it all off (jetwasher) do the inner wing too it's a nice colour that and a shame to see it cruddy :p
