Oil Pressure Sender
Jonzy
Going to finally attempt to fit my sender this weekend, done a search and cant find a definate answer.
I cannot see a a 'spare' bolt on the top of the oil filter assembly. What I can see is a hex head fitting, which appears to have a solid banjo type fitting coming from it.
Any other suggestions? Also is the thread on the standard autometer sender unit sutiable or will I need a thread converter?
Jonzy
I got a load todo sat mate, n75 change - finish up my n249 relocation and have a look @ this sender unit too. Welcome to pop up fella, dunno which house ill be at though :)
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
How many you got?
LOL i may pop over if its ok anyway mate, just for a chat, as i've got nothing planned for tomoz.
What time would you be starting? I'm an early bird!
Jonzy
Depends on my work load today, I may have to work a few hours in the morning first. Txt me about 9ish, find out where I am.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
PMSL Carl, mines months and months old too! Bought all three gauges, and only fitted the boost gauge, because i could replace the other one!
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
god damn it guys, i'd love to come and give you all a hand but im working tomorrow! unless you all fancy popping round Uplands once your done and I'll sell you all some audio system upgrades lol!
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Remove the bracket which holds the dipstick in place, this makes it easier to see. You will need a 5mm allen key to remove it, Put some sealer on the sender threads when you put it in.
Its a fidley job.
Jonzy
Martin, yea i know - if its a banjo fitting, which it is, you wouldnt be able to fit the sender there.
I had a good look today and I can see another bolt further up which appears to drop vertically into the housing. Ive had enough of the pissy tempremental bitch car today anyway - its gunno end up torched soon :lol:
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
whys thats it gone and done on you today then? sorry to rub it in and touch wood but mines running fantastically!
Jonzy
n249 & sec vac is all been relocated to the scuttle panel, managed to snap securing lug on one the coilpacks in the process. Intermittent misfire on startup then, luckily had a spare connector.
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
I used a bit of sump sealer on the threads of the sender. Sorry i dont have any pics good enough for you to see anything.
Prebs
662
Norway, Bergen
Does anyone know if you need 2 senders for fitting both oil pressure and oil temp gauges or if it possible to use 1 sender.
Prebs
