Hi Guys,
I've had the cupra now for nearly a month now.
I've already spent £500.00 (cambelt/waterpump/tyres and Y shaped breather pipe).
When I changed the breatehr pipe do to it being split, and previous owner using gaffer tape. I found that the the Y and ajoining pipe work all sludge. She drives fine, but she has had an oil change so this shouldn't be the case.
I can only presume that the engine hasn't been "flushed" out, or is there another reason?
Also I'm changing some of the OEM pipes for silicone, coming off the header tank. There are two strange clips holding two of the three pipes, how do you get them off without breaking them?
I will take pictures to show you what I mean.
