Oil Temp warning light.
Tuck3r
87
R.C.T.
Hi all,
Got in my car this morning to come to work and the oil temp light flashed red and beeped at me three times.
i believe this is low coolant level, i checked the level and even though it was low it was not below the minimum.
i decided not to risk it and took my other car to work.
as i dont have a seat dealer near me i was just wondering if anyone knows what coolant i can get from halfords so i go out on dinner break and pick some up.
my car is a 03 lcr by the way.
cheers.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
How can an oil temp flash and be a coolant level?
If you mean the red light in the temperature gauge then yes either coolant is low, or the prongs inside the header tank need a scrape.
If you need coolant you need G12 dark blue bottle iirc, check on the rear it's for Seats.
Tuck3r
87
R.C.T.
ah i see ive got that wrong then.
Yes it is the red light in the temperature gauge.
i'll have a look to see what coolant they have. thanks for the quick reply.
Tuck3r
87
R.C.T.
Halfords also do a G12+ (pink) equivalent, some cars use that. Don't mix what you have though, if you're not sure then I believe it's safer to just top up with a little water, as mixing different coolants could result in the whole lot turning to gel as it reacts.
Ah i see. mine coolant is pink, but i think the safest option will be to add water.
my car is going in for a little bit of work on Wednesday, and as they did the service i will have them to have a look at it.
