Oil Temperature shows below normal , shows 60
Avyuk
Hi ,
I am having Seat Toldeo 2.3 V5 (1999 Model). I left the car for a week outside in open parking and it was snowing. After a week , when I started the car there was beep ( 3 times) for oil temperature and red indicator flashing for oil temperature.The beeps sound ended after few beeps , but the red indicator continued to flash
I left car started and after few minutes the the red indicator vanished and the oil temperature increased from 60 to 90 . I could drive the car. But , evening again i tried to start the car , the same problem happened.
Similarly , i left car started and problem vanished.
Not sure what is the problem.Please assist me. Any help will be highly appreciated.
Avyuk
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Are you on about the red light in the coolant gauge area?
If so don't panic scrape the prongs in the header tank and/or top up the coolant with G12.
Avyuk
Hi Lee,
Thanks for the solution. After the top up of the coolant , the problem vanished.
But , I did monitor the coolant level . I filled upto the maximum level . After 3 weeks , it is going to reach the minimum level .
Is that normal ? or there may be a leakage ?
If so, is that big work to get it corrected ? cost more money ?
Please advise. Any help will be highly appreciated.
Avyuk
Avyuk
Hi Lee,
Thanks for the reply.
I would like to know how serious it is ? and how costly it will be to get it fixed from garage ? Any idea ? (I am living in Netherlands )
The web page explains about the possible causes. I have very minimum experience with this kind of tasks.
Please let me know your view on this.
Thanks once again for the guidance
Avyuk
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Basically your looking for the escape of the coolant which is normally a crystallisation on pipes/ around hose clips.
You haven't lost a lot, but you have lost some.
The coolant cap might be faulty if you can't find any other sign of leakage.
Avyuk
hi,
I checked the coolant cap. Seems to be fine.
tomorrow morning i will check the hose and let u know.
In worst case , how much it cost ? please give ma rough indication
