Oil temperature??
Jamesemt
149
Hull
I've just fitted an oil temp gauge to my Ibiza, but think the sender is getting too much airflow as I've fitted it where the pressure sensor is. What's a normal temp for the 130/160TDI?
muddyboots
Still hanging around
Oct 16, 2002
5,739
My remapped 130 Ibiza generally sat at 90º during normal day-to-day driving, IE same as water temp.
But you'll find that oil temp takes quite a long time to reach operating temp compared to the water.
But during hard runs it could break 100º; and once on a several mile stretch of uphill autoroute in France, fully loaded up at 100mph+, ambient temps around 30º, oil temp started creeping up to around 115-120º...needless to say I let it idle for a good few minutes before switching off when I pulled into a service area !
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
I've got my oil temp sender bolted firmly into the sump. This does mean it reads a little lower than the highest point during it's journey around the engine/turbo. I tend to see mid 70s on light cruises, 80 degrees on slightly faster runs, and last night I had it to 90 degrees on a fast motorway uphill run.
What gauge are you using? I got quite a tasty SPA gauge so I can monitor coolant and oil temps on the same 52mm pod. :)
Oil does take a long time to warm up too. I noticed this as I used to think it was safe to use more throttle when the coolant needle started lifting off the bottom. Then I found out the coolant is actually only about 40 degrees at this point, and oil still down at around 25 degrees. Now I usually wait for the oil to reach 40 degrees. The car feels a bit more eager to move when the oil reaches this temp.
Jamesemt
149
Hull
Cheers guys - I've got a Spa analogue gauge. Just ordered a stainless steel air filter heat shield which I might be able to cut to fit...
How long does it take you to get up to 70/80 degrees?
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
In the sump? Sometimes it can be upwards of 15 minutes - usually depends on how progressive I'm being. On my 40mph dawdle commute, it can take quite some time.
muddyboots
Oct 16, 2002
5,739
Used to take 15+ minutes in my Ibiza on my daily journey to work.
